“dict check key” TypeError
Home Forums Puzzles “dict check key” TypeError
  • #25208
    chaac
    When i use “dict check key” i can’t save the Puzzle.
    Console LOG:
    TypeError: "Expecting valid order from value block: dictCheck"
    valueToCode http://localhost:8668/puzzles/puzzles.min.js:1
        controls_if http://localhost:8668/puzzles/puzzles.min.js:1
        blockToCode http://localhost:8668/puzzles/puzzles.min.js:1
        scrub_ http://localhost:8668/puzzles/puzzles.min.js:1
        statementToCode http://localhost:8668/puzzles/puzzles.min.js:1
        controls_forEach http://localhost:8668/puzzles/puzzles.min.js:1
        workspaceToCode http://localhost:8668/puzzles/puzzles.min.js:1
        generateCode http://localhost:8668/puzzles/puzzles.min.js:1
        a http://localhost:8668/puzzles/puzzles.min.js:1
        onSave http://localhost:8668/puzzles/puzzles.min.js:1
        invokeWithErrorHandling http://localhost:8668/puzzles/puzzles.min.js:1
        r http://localhost:8668/puzzles/puzzles.min.js:1
        _wrapper http://localhost:8668/puzzles/puzzles.min.js:1
    puzzles.min.js:1:899413
        logError http://localhost:8668/puzzles/puzzles.min.js:1
        globalHandleError http://localhost:8668/puzzles/puzzles.min.js:1
        handleError http://localhost:8668/puzzles/puzzles.min.js:1
    But it also works with “dict get key” ;-)
    #25256
    what version of Verge3D are you using?
    #25369
    Hi chaac,
    Thanks for the report, we just fixed the bug. That puzzle should work properly in the next verge3d update. For now to make it work you can replace the file puzzles/puzzles.min.js in the verge3d SDK with the fixed version from the attached archive.
