Home › Forums › Graphics / Blender › Diamond Rendering
- This topic has 30 replies, 5 voices, and was last updated 4 years, 7 months ago by cristianctin.
2020-04-23 at 3:19 pm #26476cristianctinCustomer
Hello,
I am testing the trial version.
In your demo the diamonds are very nice but I would like to be as in meisterschmuck.ch as there is more contrast and shiny.
https://www.meisterschmuck.ch/shop/en/engagement-rings/Engagement-Ring-31-2-7-mm-0101-0000-0000-1-Brill-0-45-ct-G-VS-53-mm.html
Could you please tell me if you have a diamond set up so that it will render the same?
A suggestion on how to render it the same will be very useful.
Thank you2020-04-24 at 5:32 am #26492Mikhail LuzyaninStaffThey have different nature, but you can try to tweak the material from the engines repository to get the result you needed if you have enough skills.
2020-04-24 at 5:48 am #26493cristianctinCustomerHi,
Thank you for the reply.
I have already tried to tweak it, and tested many variations but I did not get even close to what they made.
Could you please elaborate a bit “They have different nature” ?
What do you mean by that ?
They have another software ?
Thank you2020-04-24 at 6:14 am #26495Mikhail LuzyaninStaffCould you please elaborate a bit “They have different nature” ?
They used another software (Blend4Web) and they used another type of shaders so they work different, but I’m shure that you can achieve the same effect using Verge3D engines, because we already made once the same shader for customer, that was a copy of this shader you shared, but unfrotunally I can’t share it. Using this shader that uncluded in the engines repo you can try to change an HDRI environment map to get closer look, because most of reflecation and all look depend on HDRI environmant map stricktly.
2020-04-24 at 8:55 am #26511cristianctinCustomerHi,
Thank you for clarification.
I will follow your recommendation and work on your demo diamond shaders and change the HDRI.
Hopefully I will make the right HDRI and get the shiny diamond I need.
Thank you for your kind support2020-05-01 at 4:02 pm #27067cristianctinCustomerHi,
I have changed many HDRI and make some of them from scratch.
Unfortunately I get some jagged margins on the diamond and metal.
Do you have any suggestion on how to eliminate this jagged edges?
I am attaching an image to see them.
Thank you2020-05-01 at 4:47 pm #27069Mikhail LuzyaninStaffTry to use settings for a refraction from jewelry configurator. You also may increase cubemap resolution for refraction in lightprobe settings of render panel in Blender. Also try to increase multiplier of the canvas using Set Screen Scale puzzle with 1.5 – 2.0 value.
2020-05-01 at 9:16 pm #27071cristianctinCustomerHi,
There are improvements by adding Set Screen Scale puzzle to 2.
However I can not see the the improvements in browser.
Have you any idea why ?
Please see the attached image.
Thank you
Edited:
When I decrease the browser window I can see the improvements.
When I maximize the browser window or I am in full screen from the Verge3D toggle fullscreen mode I can not see the improvements2020-05-02 at 1:08 am #27075GLiFTeKCustomerYou could add a tiny bevel to your hard edges to catch extra specular detail.
In the real world there are no perfect edges… (Yet ;) )
plz share Discord link & on your signature!2020-05-02 at 7:12 am #27081cristianctinCustomerHi,
Thank you for your suggestion.
I applied the bevel, but no changes.
However, on diamonds it looks unrealistic to apply round edges, even tiny ones.
The diamonds models ( inner and outer ) in Jewelry Configurator are fine, there is not need to model another ones, but I need the render without jagged edges.
Thank you.2020-05-02 at 10:20 am #27090cristianctinCustomerHi Mikhail,
Just to inform you.
I have just purchased the software.
It was purchased from a new account adamevediamonds@gmail.com
Regards2020-05-02 at 10:24 am #27092Mikhail LuzyaninStaffCan you share you app so I can try to tweak it.
2020-05-02 at 10:45 am #27097cristianctinCustomerHi,
Sure yes.
Can I attached here on the forum or send it you by an email?
Thank you2020-05-02 at 10:53 am #27099cristianctinCustomerHi,
The app has 2,4 MB I believe I can attached it.
Thank you2020-05-04 at 8:37 pm #27168cristianctinCustomerHi,
Could you please check this link.
https://www.adamevediamonds.com/ro/verighete-clasice-3-mm/verighete-clasice-aur-alb-14k-aed192935v
I am testing an application without any diamond.
The model has jagged edges.
Is there any settings to make and remove these jagged edges?
Thank you -
