Desktop Electron App Help
Home Forums Programming Desktop Electron App Help
  • #46362
    jdhutchinson
    Hi, how can I make a ‘true’ fullscreen app with the electron method? So far, I have been able to use the F11 key to toggle fullscreen, OR use the verge3d advice to remove the menu in the main.js file.
    How can I get the best of both worlds, or run the exe that is made in a kiosk style mode.
    Also, is it in theory possible to ‘update’ the app by replacing and tweaking files in the \resources\app folder, which appears to just be a clone of a projects folder in the App Manager.
    #46368
    you can do it as shown here
    https://www.electronjs.org/docs/latest/api/frameless-window
    #46370
    jdhutchinson
    Hi Yuri,
    It seems the key line of code to add is autoHideMenuBar: true !
    This removes the menu, but also allows F11 to still be pressed for fullscreen. Maybe worth adding to the documentation for people to be able to create kiosk apps?
    const { app, BrowserWindow } = require(‘electron’);
    function createWindow() {
    // create the browser window
    const win = new BrowserWindow({
    width: 1280,
    height: 800,
    autoHideMenuBar: true,
    webPreferences: {
    nodeIntegration: true
    // and load the main file of the app
    win.loadFile(‘index.html’);
    //win.removeMenu();
    app.whenReady().then(createWindow);
    #46396
    glad you worked it out, and thanks for the suggestion! :good:
