Home › Forums › Graphics / Blender › Cycles Materials
- This topic has 18 replies, 4 voices, and was last updated 6 years, 5 months ago by
Yuri Kovelenov.
2018-10-30 at 7:02 pm #8546
adcornetto
CustomerCycles materials do not work for me. I opened the spinner.blend file and hit sneak peak and nothing shows up besides the background. Am I missing a setting?
Thanks,
T2018-10-31 at 6:23 am #8547Mikhail Luzyanin
StaffCycles materials do not work for me. I opened the spinner.blend file and hit sneak peak and nothing shows up besides the background. Am I missing a setting?
Thanks,It’s strange because it’s work for us. May be there some erors in the browser consol can you share a screenshot?
2018-10-31 at 9:44 am #8555Yuri Kovelenov
Staff2018-10-31 at 7:08 pm #8565adcornetto
CustomerI am using Google Chrome.
The only thing that shows up is the environment background.
I turned on ambient occlusion in the viewer and you can see the outline of the 3d objects. (see attached image).2018-11-01 at 7:54 am #8575Alexander Kovelenov
Staff2018-11-01 at 1:03 pm #8589adcornetto
CustomerGraphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Out-of-process Rasterization: Disabled
Hardware Protected Video Decode: Unavailable
Rasterization: Hardware accelerated
Skia Deferred Display List: Disabled
Skia Renderer: Disabled
Surface Synchronization: Enabled
Video Decode: Hardware accelerated
Viz Service Display Compositor: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
decode_encode_srgb_for_generatemipmap
disable_delayed_copy_nv12
disable_discard_framebuffer
disable_framebuffer_cmaa
exit_on_context_lost
force_cube_complete
scalarize_vec_and_mat_constructor_args
disabled_extension_GL_KHR_blend_equation_advanced
disabled_extension_GL_KHR_blend_equation_advanced_coherent
Problems Detected
Protected video decoding with swap chain is for Windows and Intel only
Disabled Features: protected_video_decode
Some drivers are unable to reset the D3D device in the GPU process sandbox
Applied Workarounds: exit_on_context_lost
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
ANGLE crash on glReadPixels from incomplete cube map texture: 518889
Applied Workarounds: force_cube_complete
Framebuffer discarding can hurt performance on non-tilers: 570897
Applied Workarounds: disable_discard_framebuffer
Use GL_INTEL_framebuffer_CMAA on ChromeOS: 535198
Applied Workarounds: disable_framebuffer_cmaa
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Decode and Encode before generateMipmap for srgb format textures on Windows: 634519
Applied Workarounds: decode_encode_srgb_for_generatemipmap
Delayed copy NV12 displays incorrect colors on NVIDIA drivers.: 728670
Applied Workarounds: disable_delayed_copy_nv12
Native GpuMemoryBuffers have been disabled, either via about:flags or command line.
Disabled Features: native_gpu_memory_buffers
Viz service display compositor is not enabled by default.
Disabled Features: viz_display_compositor
Skia renderer is not used by default.
Disabled Features: skia_renderer
Skia deferred display list is not used by default.
Disabled Features: skia_deferred_display_list
Version Information
Data exported 2018-11-01T13:01:55.078Z
Chrome version Chrome/70.0.3538.77
Operating system Windows NT 10.0.17763
Software rendering list URL https://chromium.googlesource.com/chromium/src/+/0f6ce0b0cd63a12cb4eccea3637b1bc9a29148d9/gpu/config/software_rendering_list.json
Driver bug list URL https://chromium.googlesource.com/chromium/src/+/0f6ce0b0cd63a12cb4eccea3637b1bc9a29148d9/gpu/config/gpu_driver_bug_list.json
ANGLE commit id 05c729f336ef
2D graphics backend Skia/70 193565807f7fd2a2c14e21b44c545cc03ebe134f-
Command Line “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” –flag-switches-begin –flag-switches-end
Driver Information
Initialization time 599
In-process GPU false
Passthrough Command Decoder false
Sandboxed true
GPU0 VENDOR = 0x10de, DEVICE= 0x1401 *ACTIVE*
GPU1 VENDOR = 0x10de, DEVICE= 0x1b80
GPU2 VENDOR = 0x10de, DEVICE= 0x1b80
Optimus false
AMD switchable false
Desktop compositing Aero Glass
Direct Composition true
Supports overlays false
Overlay capabilities
Diagonal Monitor Size of \\.\DISPLAY2 27.0″
Diagonal Monitor Size of \\.\DISPLAY4 25.9″
Diagonal Monitor Size of \\.\DISPLAY3 27.8″
Diagonal Monitor Size of \\.\DISPLAY1 27.0″
Driver D3D12 feature level D3D 12.1
Driver Vulkan API version Vulkan API 1.1.0
Driver vendor NVIDIA
Driver version 399.24
Driver date 9-5-2018
GPU CUDA compute capability major version 5
Pixel shader version 5.0
Vertex shader version 5.0
Max. MSAA samples 8
Machine model name
Machine model version
GL_VENDOR Google Inc.
GL_RENDERER ANGLE (NVIDIA GeForce GTX 960 Direct3D11 vs_5_0 ps_5_0)
GL_VERSION OpenGL ES 2.0 (ANGLE 2.1.0.05c729f336ef)
GL_EXTENSIONS GL_ANGLE_client_arrays GL_ANGLE_depth_texture GL_ANGLE_explicit_context GL_ANGLE_explicit_context_gles1 GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_lossy_etc_decode GL_ANGLE_pack_reverse_row_order GL_ANGLE_program_cache_control GL_ANGLE_request_extension GL_ANGLE_robust_client_memory GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ANGLE_texture_usage GL_ANGLE_translated_shader_source GL_CHROMIUM_bind_generates_resource GL_CHROMIUM_bind_uniform_location GL_CHROMIUM_color_buffer_float_rgb GL_CHROMIUM_color_buffer_float_rgba GL_CHROMIUM_copy_compressed_texture GL_CHROMIUM_copy_texture GL_CHROMIUM_sync_query GL_EXT_blend_minmax GL_EXT_color_buffer_half_float GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers GL_EXT_frag_depth GL_EXT_map_buffer_range GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_robustness GL_EXT_sRGB GL_EXT_shader_texture_lod GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc_srgb GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_EXT_texture_storage GL_EXT_unpack_subimage GL_KHR_debug GL_KHR_parallel_shader_compile GL_NV_EGL_stream_consumer_external GL_NV_fence GL_NV_pack_subimage GL_NV_pixel_buffer_object GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth32 GL_OES_element_index_uint GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object OES_compressed_EAC_R11_signed_texture OES_compressed_EAC_R11_unsigned_texture OES_compressed_EAC_RG11_signed_texture OES_compressed_EAC_RG11_unsigned_texture OES_compressed_ETC2_RGB8_texture OES_compressed_ETC2_RGBA8_texture OES_compressed_ETC2_punchthroughA_RGBA8_texture OES_compressed_ETC2_punchthroughA_sRGB8_alpha_texture OES_compressed_ETC2_sRGB8_alpha8_texture OES_compressed_ETC2_sRGB8_texture
Disabled Extensions GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Disabled WebGL Extensions
Window system binding vendor Google Inc. (adapter LUID: 0000000000015ec4)
Window system binding version 1.4 (ANGLE 2.1.0.05c729f336ef)
Window system binding extensions EGL_EXT_create_context_robustness EGL_ANGLE_d3d_share_handle_client_buffer EGL_ANGLE_d3d_texture_client_buffer EGL_ANGLE_surface_d3d_texture_2d_share_handle EGL_ANGLE_query_surface_pointer EGL_ANGLE_window_fixed_size EGL_ANGLE_keyed_mutex EGL_ANGLE_surface_orientation EGL_ANGLE_direct_composition EGL_NV_post_sub_buffer EGL_KHR_create_context EGL_EXT_device_query EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_get_all_proc_addresses EGL_KHR_stream EGL_KHR_stream_consumer_gltexture EGL_NV_stream_consumer_gltexture_yuv EGL_ANGLE_flexible_surface_compatibility EGL_ANGLE_stream_producer_d3d_texture EGL_ANGLE_create_context_webgl_compatibility EGL_CHROMIUM_create_context_bind_generates_resource EGL_CHROMIUM_sync_control EGL_EXT_pixel_format_float EGL_KHR_surfaceless_context EGL_ANGLE_display_texture_share_group EGL_ANGLE_create_context_client_arrays EGL_ANGLE_program_cache_control EGL_ANGLE_robust_resource_initialization EGL_ANGLE_create_context_extensions_enabled
Direct rendering Yes
Reset notification strategy 0x8252
GPU process crash count 0
Compositor Information
Tile Update Mode One-copy
Partial Raster Enabled
GpuMemoryBuffers Status
ATC Software only
ATCIA Software only
DXT1 Software only
DXT5 Software only
ETC1 Software only
R_8 Software only
R_16 Software only
RG_88 Software only
BGR_565 Software only
RGBA_4444 Software only
RGBX_8888 GPU_READ, SCANOUT
RGBA_8888 GPU_READ, SCANOUT
BGRX_8888 Software only
BGRX_1010102 Software only
RGBX_1010102 Software only
BGRA_8888 Software only
RGBA_F16 Software only
YVU_420 Software only
YUV_420_BIPLANAR Software only
UYVY_422 Software only
Display(s) Information
Info Display[2528732444] bounds=[0,0 1920×1080], workarea=[0,0 1920×1040], scale=1, external.
Color space information {primaries:BT709, transfer:IEC61966_2_1, matrix:RGB, range:FULL}
Bits per color component 8
Bits per pixel 24
Info Display[2779098405] bounds=[1920,0 1920×1080], workarea=[1920,0 1920×1040], scale=1, external.
Bits per pixel 24
Info Display[2841568472] bounds=[-2560,0 2560×1440], workarea=[-2560,0 2560×1400], scale=1.5, external.
Bits per pixel 24
Info Display[2480450848] bounds=[0,1080 1920×1080], workarea=[0,1080 1920×1040], scale=1, external.
Bits per pixel 24
Video Acceleration Information
Decode h264 baseline up to 4096×2304 pixels
Decode h264 baseline up to 2304×4096 pixels
Decode h264 main up to 4096×2304 pixels
Decode h264 main up to 2304×4096 pixels
Decode h264 high up to 4096×2304 pixels
Decode h264 high up to 2304×4096 pixels
Decode vp8 up to 4096×2304 pixels
Decode vp8 up to 2304×4096 pixels
Decode vp9 profile0 up to 4096×2304 pixels
Decode vp9 profile0 up to 2304×4096 pixels
Decode vp9 profile1 up to 4096×2304 pixels
Decode vp9 profile1 up to 2304×4096 pixels
Decode vp9 profile2 up to 4096×2304 pixels
Decode vp9 profile2 up to 2304×4096 pixels
Decode vp9 profile3 up to 4096×2304 pixels
Decode vp9 profile3 up to 2304×4096 pixels
Encode h264 baseline up to 3840×2176 pixels and/or 30.000 fps
Encode h264 main up to 3840×2176 pixels and/or 30.000 fps
Encode h264 high up to 3840×2176 pixels and/or 30.000 fps
Diagnostics
0
b3DAccelerationEnabled true
b3DAccelerationExists true
bAGPEnabled true
bAGPExistenceValid true
bAGPExists true
bCanRenderWindow true
bDDAccelerationEnabled true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bDriverSignedValid false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 0
lDriverSize 952800
lMiniVddSize 0
szAGPStatusEnglish Enabled
szAGPStatusLocalized Enabled
szChipType GeForce GTX 960
szD3DStatusEnglish Enabled
szD3DStatusLocalized Enabled
szDACType Integrated RAMDAC
szDDIVersionEnglish 12
szDDIVersionLocalized 12
szDDStatusEnglish Enabled
szDDStatusLocalized Enabled
szDXVAHDEnglish Supported
szDXVAModes
szDescription NVIDIA GeForce GTX 960
szDeviceId 0x1401
szDeviceIdentifier {D7B71E3E-5741-11CF-367D-6A191BC2D535}
szDeviceName \\.\DISPLAY1
szDisplayMemoryEnglish 36794 MB
szDisplayMemoryLocalized 36794 MB
szDisplayModeEnglish 1920 x 1080 (32 bit) (60Hz)
szDisplayModeLocalized 1920 x 1080 (32 bit) (60Hz)
szDriverAssemblyVersion 24.21.13.9924
szDriverAttributes Final Retail
szDriverDateEnglish 9/4/2018 8:00:00 PM
szDriverDateLocalized 9/4/2018 20:00:00
szDriverLanguageEnglish English
szDriverLanguageLocalized English
szDriverModelEnglish WDDM 2.4
szDriverModelLocalized WDDM 2.4
szDriverName C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_8e4f37220e99138f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_8e4f37220e99138f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_8e4f37220e99138f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_8e4f37220e99138f\nvldumdx.dll
szDriverNodeStrongName oem22.inf:0f066de3d2368449:Section076:24.21.13.9924:pci\ven_10de&dev_1401
szDriverSignDate Unknown
szDriverVersion 24.21.0013.9924
szKeyDeviceID Enum\PCI\VEN_10DE&DEV_1401&SUBSYS_39673842&REV_A1
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{863301CF-C7ED-11E8-93BA-3497F600C116}\0000
szManufacturer NVIDIA
szMiniVdd unknown
szMiniVddDateEnglish Unknown
szMiniVddDateLocalized unknown
szMonitorMaxRes Unknown
szMonitorName Generic PnP Monitor
szNotesEnglish No problems found.
szNotesLocalized No problems found.
szOverlayEnglish Supported
szRankOfInstalledDriver 00D12001
szRegHelpText Unknown
szRevision Unknown
szRevisionId 0x00A1
szSubSysId 0x39673842
szTestResultD3D7English Not run
szTestResultD3D7Localized Not run
szTestResultD3D8English Not run
szTestResultD3D8Localized Not run
szTestResultD3D9English Not run
szTestResultD3D9Localized Not run
szTestResultDDEnglish Not run
szTestResultDDLocalized Not run
szVdd unknown
szVendorId 0x10DE
1
bAGPEnabled true
bAGPExists true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 1
lDriverSize 952800
lMiniVddSize 0
szDXVAModes
szDeviceId 0x1401
szDeviceName \\.\DISPLAY2
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{863301CF-C7ED-11E8-93BA-3497F600C116}\0001
szMiniVdd unknown
szRevision Unknown
szRevisionId 0x00A1
szVdd unknown
szVendorId 0x10DE
2
bAGPEnabled true
bAGPExists true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 2160
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 3840
iAdapter 2
lDriverSize 952800
lMiniVddSize 0
szDXVAModes
szDeviceId 0x1401
szDeviceName \\.\DISPLAY3
szDisplayModeEnglish 3840 x 2160 (32 bit) (60Hz)
szDisplayModeLocalized 3840 x 2160 (32 bit) (60Hz)
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{863301CF-C7ED-11E8-93BA-3497F600C116}\0002
szMiniVdd unknown
szRevision Unknown
szRevisionId 0x00A1
szVdd unknown
szVendorId 0x10DE
3
bAGPEnabled true
bAGPExists true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 3
lDriverSize 952800
lMiniVddSize 0
szDXVAModes
szDeviceId 0x1401
szDeviceName \\.\DISPLAY4
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{863301CF-C7ED-11E8-93BA-3497F600C116}\0003
szMiniVdd unknown
szRevision Unknown
szRevisionId 0x00A1
szVdd unknown
szVendorId 0x10DE
4
bAGPEnabled true
bAGPExistenceValid false
bAGPExists false
bCanRenderWindow false
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 0
dwDDIVersion 12
dwHeight 0
dwRefreshRate 0
dwWHQLLevel 0
dwWidth 0
iAdapter 0
lDriverSize 952800
lMiniVddSize 0
szChipType GeForce GTX 1080
szDXVAHDEnglish Unknown
szDXVAModes Unknown
szDescription NVIDIA GeForce GTX 1080
szDeviceId 0x1B80
szDeviceIdentifier Unknown
szDeviceName Unknown
szDisplayMemoryEnglish 40820 MB
szDisplayMemoryLocalized 40820 MB
szDisplayModeEnglish Unknown
szDisplayModeLocalized unknown
szDriverNodeStrongName oem22.inf:0f066de361856a84:Section102:24.21.13.9924:pci\ven_10de&dev_1b80
szKeyDeviceID Enum\PCI\VEN_10DE&DEV_1B80&SUBSYS_62823842&REV_A1
szKeyDeviceKey Unknown
szMiniVdd unknown
szMonitorName Unknown
szOverlayEnglish Unknown
szRevision Unknown
szRevisionId 0x00A1
szSubSysId 0x62823842
szVdd unknown
szVendorId 0x10DE
5
bAGPEnabled true
bAGPExists false
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 0
dwDDIVersion 12
dwHeight 0
dwRefreshRate 0
dwWHQLLevel 0
dwWidth 0
iAdapter 0
lDriverSize 952800
lMiniVddSize 0
szDXVAModes Unknown
szDeviceId 0x1B80
szKeyDeviceID Enum\PCI\VEN_10DE&DEV_1B80&SUBSYS_62883842&REV_A1
szMiniVdd unknown
szRevision Unknown
szRevisionId 0x00A1
szSubSysId 0x62883842
szVdd unknown
szVendorId 0x10DE
Log Messages
GpuProcessHostUIShim:
GpuProcessHostUIShim:2018-11-01 at 1:34 pm #8590Alexander Kovelenov
StaffThank you very much. Your hardware seems to be fine. Can you also provide us with log from your browser’s console? Press F12 while running your app, switch to “Console” tab and then copy the content of the console and send back to us. BTW, does the Industrial Robot application works for you?
2018-11-01 at 1:57 pm #8591adcornetto
CustomerVerge3D 2.7.1
v3d.js:1 v3d.WebGLShader: Shader couldn’t compile.
ga @ v3d.js:1v3d.js:1 v3d.WebGLShader: gl.getShaderInfoLog() fragment ERROR: 0:1458: ‘node_output_material’ : no matching overloaded function found
1: #extension GL_OES_standard_derivatives : enable
2: #extension GL_EXT_shader_texture_lod : enable
3: precision highp float;
4: precision highp int;
5: #define SHADER_NAME MeshNodeMaterial
6: #define LIGHT_PATH_IS_CAM_RAY 1
7: #define WORLD_NODES 0
8: #define BLENDER_LIGHTS
9: #define NODE_RGB_NUM 1
10: #define NODE_VALUE_NUM 0
11: #define NODE_RGB
12: #define NODE_BSDF_PRINCIPLED
13: #define NODE_OUTPUT_MATERIAL
14: #define PHYSICAL
15: #define STANDARD
16: #define GAMMA_FACTOR 2
17: #define USE_ENVMAP
18: #define ENVMAP_TYPE_CUBE_UV
19: #define ENVMAP_MODE_REFLECTION
20: #define ENVMAP_BLENDING_MULTIPLY
21: #define NUM_CLIPPING_PLANES 0
22: #define UNION_CLIPPING_PLANES 0
23: #define PHYSICALLY_CORRECT_LIGHTS
24: #define UNITS_SCALE_FACTOR 1.0
25: #define TEXTURE_LOD_EXT
26: uniform mat4 viewMatrix;
27: uniform vec3 cameraPosition;
28: #define TONE_MAPPING
29: #define saturate(a) clamp(a, 0.0, 1.0)
30: uniform float toneMappingExposure;
31: uniform float toneMappingWhitePoint;
32: vec3 LinearToneMapping(vec3 color) {
33: return toneMappingExposure * color;
34: }
35: vec3 ReinhardToneMapping(vec3 color) {
36: color *= toneMappingExposure;
37: return saturate(color / (vec3(1.0) + color));
38: }
39: #define Uncharted2Helper(x) max(((x * (0.15 * x + 0.10 * 0.50) + 0.20 * 0.02) / (x * (0.15 * x + 0.50) + 0.20 * 0.30)) – 0.02 / 0.30, vec3(0.0))
40: vec3 Uncharted2ToneMapping(vec3 color) {
41:
42: color *= toneMappingExposure;
43: return saturate(Uncharted2Helper(color) / Uncharted2Helper(vec3(toneMappingWhitePoint)));
44: }
45: vec3 OptimizedCineonToneMapping(vec3 color) {
46:
47: color *= toneMappingExposure;
48: color = max(vec3(0.0), color – 0.004);
49: return pow((color * (6.2 * color + 0.5)) / (color * (6.2 * color + 1.7) + 0.06), vec3(2.2));
50: }
51: vec3 LogarithmicToneMapping(vec3 color) {
52: return log(color + 1.0) / log(toneMappingExposure + 1.0);
53: }
54:
55: vec3 toneMapping(vec3 color) { return LinearToneMapping(color); }
56:
57: vec4 LinearToLinear(in vec4 value) {
58: return value;
59: }
60: vec4 GammaToLinear(in vec4 value, in float gammaFactor) {
61: return vec4(pow(value.xyz, vec3(gammaFactor)), value.w);
62: }
63: vec4 LinearToGamma(in vec4 value, in float gammaFactor) {
64: return vec4(pow(value.xyz, vec3(1.0 / gammaFactor)), value.w);
65: }
66: vec4 sRGBToLinear(in vec4 value) {
67: return vec4(mix(pow(value.rgb * 0.9478672986 + vec3(0.0521327014), vec3(2.4)), value.rgb * 0.0773993808, vec3(lessThanEqual(value.rgb, vec3(0.04045)))), value.w);
68: }
69: vec4 LinearTosRGB(in vec4 value) {
70: return vec4(mix(pow(value.rgb, vec3(0.41666)) * 1.055 – vec3(0.055), value.rgb * 12.92, vec3(lessThanEqual(value.rgb, vec3(0.0031308)))), value.w);
71: }
72: vec4 RGBEToLinear(in vec4 value) {
73: return vec4(value.rgb * exp2(value.a * 255.0 – 128.0), 1.0);
74: }
75: vec4 LinearToRGBE(in vec4 value) {
76: float maxComponent = max(max(value.r, value.g), value.b);
77: float fExp = clamp(ceil(log2(maxComponent)), -128.0, 127.0);
78: return vec4(value.rgb / exp2(fExp), (fExp + 128.0) / 255.0);
79: }
80: vec4 RGBMToLinear(in vec4 value, in float maxRange) {
81: return vec4(value.xyz * value.w * maxRange, 1.0);
82: }
83: vec4 LinearToRGBM(in vec4 value, in float maxRange) {
84: float maxRGB = max(value.x, max(value.g, value.b));
85: float M = clamp(maxRGB / maxRange, 0.0, 1.0);
86: M = ceil(M * 255.0) / 255.0;
87: return vec4(value.rgb / (M * maxRange), M);
88: }
89: vec4 RGBDToLinear(in vec4 value, in float maxRange) {
90: return vec4(value.rgb * ((maxRange / 255.0) / value.a), 1.0);
91: }
92: vec4 LinearToRGBD(in vec4 value, in float maxRange) {
93: float maxRGB = max(value.x, max(value.g, value.b));
94: float D = max(maxRange / maxRGB, 1.0);
95: D = min(floor(D) / 255.0, 1.0);
96: return vec4(value.rgb * (D * (255.0 / maxRange)), D);
97: }
98: const mat3 cLogLuvM = mat3(0.2209, 0.3390, 0.4184, 0.1138, 0.6780, 0.7319, 0.0102, 0.1130, 0.2969);
99: vec4 LinearToLogLuv(in vec4 value) {
100: vec3 Xp_Y_XYZp = value.rgb * cLogLuvM;
101: Xp_Y_XYZp = max(Xp_Y_XYZp, vec3(1e-6, 1e-6, 1e-6));
102: vec4 vResult;
103: vResult.xy = Xp_Y_XYZp.xy / Xp_Y_XYZp.z;
104: float Le = 2.0 * log2(Xp_Y_XYZp.y) + 127.0;
105: vResult.w = fract(Le);
106: vResult.z = (Le – (floor(vResult.w*255.0))/255.0)/255.0;
107: return vResult;
108: }
109: const mat3 cLogLuvInverseM = mat3(6.0014, -2.7008, -1.7996, -1.3320, 3.1029, -5.7721, 0.3008, -1.0882, 5.6268);
110: vec4 LogLuvToLinear(in vec4 value) {
111: float Le = value.z * 255.0 + value.w;
112: vec3 Xp_Y_XYZp;
113: Xp_Y_XYZp.y = exp2((Le – 127.0) / 2.0);
114: Xp_Y_XYZp.z = Xp_Y_XYZp.y / value.y;
115: Xp_Y_XYZp.x = value.x * Xp_Y_XYZp.z;
116: vec3 vRGB = Xp_Y_XYZp.rgb * cLogLuvInverseM;
117: return vec4(max(vRGB, 0.0), 1.0);
118: }
119:
120: vec4 mapTexelToLinear(vec4
ga @ v3d.js:1
v3d.js:1 v3d.WebGLProgram: shader error: 1282 gl.VALIDATE_STATUS false gl.getProgramInfoLog invalid shaders ERROR: 0:1458: ‘node_output_material’ : no matching overloaded function foundv3d.js:1 WebGL: too many errors, no more errors will be reported to the console for this context.
2018-11-01 at 2:16 pm #8595Yuri Kovelenov
StaffThis looks like a version mismatch between the exported gltf file (or the exporter) and the engine runtime. Are you by any chance use several verge3d installations or may be max version simultaneously with blender?
I’d recommend to reboot your system or at least restart Blender, download the latest Verge3D 2.8 and install it. Make sure the path in the addon settings corresponds to the fresh installation directory.
2018-11-01 at 2:56 pm #8600adcornetto
CustomerNot using any other installations. I deleted the verge3d directory and removed the addon, then reinstalled verge3d. Still same issue.
Not sure if it matters, but I am using Blender v2.79.6, (Branch:blender2.8)2018-11-01 at 3:13 pm #8601Yuri Kovelenov
Staff2018-11-01 at 3:24 pm #8603adcornetto
Customer2.9 pre1 worked with 2.79.6
Thanks for the help. Sorry I didn’t think about the Blender version sooner.2018-11-01 at 3:30 pm #8604Yuri Kovelenov
Staff2018-11-01 at 3:37 pm #8605adcornetto
CustomerNew issue
When click on a blend file to open from the app manager, I get a 500:Internal Server Error. The address in the browser for city.blend is the following:
“http://localhost:8668/open/?filepath=applications/city/city.blend”
Not sure if I messed up something with the blender installation. Any thoughts?
2018-11-01 at 3:58 pm #8606Yuri Kovelenov
Staff -
