Custom Preloader using WordPress/Elementor
Home Forums Programming Custom Preloader using WordPress/Elementor
  • #66085
    Brameister
    Hello!
    I’ve followed the tutorial on https://youtu.be/aUOlSgaPoXg. However, I’m using WordPress for my entire project. I found a WordPress plugin that allows me to export my pages into static html/css. However, it does not export a clean .css file like the tutorial shows in Webflow. Instead, it exports a whole bunch of .css files, none of which apparently contain the css rules for the specific preloader page. I believe this happens because wordpress is theme-based.
    I have very limited knowledge of coding and I would very much appreciate any help you can give me!
    How could I get a clean .css file like the one obtained in Webflow in order to copy the contents into my app’s .css file? That’s the last step for me, but I can’t do it.
    Thanks for your time! :good:
    #66086
    You are free to add any CSS rule via puzzles (if the problem is only in .css files)
    #66088
    Brameister
    Hi, kdv. Thank you so much for replying.
    I think I understand. My problem, however, is I don’t know where to find the CSS rules. In the tutorial, he exports the preloader page’s code and he gets a .css file that he opens in Atom and simply copies the code and pastes into the app’s .css file. In my case, when I export the page code from WordPress, I get like 7 or 8 .css files, none of which have the page’s name.
    #66089
    zip those .css files and attach here
    #66090
    Brameister
    Sure thing. Here they are!
    • This reply was modified 1 year, 8 months ago by Brameister.
    #66093
    So what’s the problem? All rules are human-readable. You don’t know the names of rules for you preloader?
    #66094
    Brameister
    Yes. Unfortunately, I’m embarrassed to say that I wouldn’t know how to identify a CSS rule if it slapped me in the face.
    My knowledge of html/css/java/coding in general is extremely limited.
    Is there any other way for me to find the CSS code that I need to paste into the app’s .css file, in order for the custom preloader to work?
    #66095
    Brameister
    For example, I can’t even seem to find in any of these css files any reference to the images used
    #66096
    It means that no rules for your preloader have been exported. Or they are inside .html files (as a variant)
    #66097
    Brameister
    I see. So the issue is probably with the WordPress plugin I’m using to export the page into HTML/CSS, right?
    Is there any other way to get this CSS information that I need (i.e. another way to export a WordPress Page into HTML/CSS)?
