Custom names to Set value Puzzle
Home Forums Puzzles Custom names to Set value Puzzle
  • #25646
    rreyes3d
    Hello, i have some materials with a lot of value nodes. inside blender they all have different names, but inside verge3d puzzles they appear as Value.00#
    is there any way to assign them a new name?
    Edit: if not, maybe i will try to combine a single Value node with some Ad/substract operations to try to cover all inputs.
    or use a Script node (which I´m not sure is supported)
    thanks
    #25650
    doehlma
    Hello,
    at me was the problem that I marked before all the options -> see under Verge3D settings in material (attachment right side)
    When I setup the Verge3D parameters like in attachment the the name was in puzzles present
    #25655
    rreyes3d
    thanks! doehlma
    also i tried to reduce the amount of values nodes, using math nodes.
    so instead of having 26 values, now I only have one.
    attached an example.
    #25693
    So everything works now as intended?
    #25694
    rreyes3d
    yes Yuri, thanks.
    but now i have to fix this issue:
    Shape key + Assign material Issue
    #25986
    markwong
    Hi Yuri, i still have the same problem although i already set the Verge3D settings in material (like showed in the attachment from doehlma)
    My custom value name is still not appear on the Puzzle. Any idea?
    The custom value name is inside the world material node by the way.
    *EDIT: My bad, the one i edit is the display, not the name, sorry
    #25991
    :good:
