Home › Forums › Graphics / Blender › Curve deform animations
- This topic has 15 replies, 3 voices, and was last updated 7 years, 1 month ago by
Yuri Kovelenov.
2018-01-11 at 4:01 pm #1614
a.gracki
CustomerHow we can play animation of a object deformed by curve ?
2018-01-11 at 4:44 pm #1621Mikhail Luzyanin
StaffHow we can play animation of a object deformed by curve ?
It’s not possible right now. But what you want to create? May be we can came up with another solution for you.
2018-01-12 at 10:43 am #1625a.gracki
CustomerI was thinking about kind of a ribbon following path, so the shape is deformed during the motion. Now I see this maybe its to complex.
Will think about something different.2018-01-12 at 1:40 pm #1628Mikhail Luzyanin
StaffI made an example for you, it’s made using only animated material.
2018-01-12 at 9:14 pm #1633a.gracki
CustomerThank You
I think this can be a good solution I don’t even think about this way2018-01-13 at 12:12 am #1634a.gracki
CustomerOk in my project I have textured object, so I need to actually move texture, so simple texture with transparency .
But the problem is I’m controlling the movement by Mapping node and I see only Value node can be use to animate material. Do You have some solution for this, will eventually use material without texturesAttachments:
You must be logged in to view attached files.2018-01-15 at 7:45 am #1663Mikhail Luzyanin
StaffHi, you can do it the same way, just look at the example. Use R chanel for U mapping and G for V mapping. Addition will shift testure and Muliply will scale texture. You need just to animate Value node and connect it to the second input of Add or Multiply node.
2018-01-15 at 11:35 pm #1666a.gracki
CustomerThank You
I was able to make it work, now it plays perfect in PUZZLE EDITOR, in RUN APPLICATION but not working once send to Verge3DNetwork, only this texture animation do not work all other object animations work perfect .
So looks like it work with local host only local server , any idea what’s can be wrong ?2018-01-16 at 7:53 am #1668Yuri Kovelenov
Staffbut not working once send to Verge3DNetwork
can you post here the link?
2018-01-16 at 1:23 pm #1670a.gracki
Customerhere is link for V network
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:b8e30a08ae/applications/TT/TT.html2018-01-16 at 1:25 pm #1671a.gracki
Customerok now it looks like this animation work correctly, so just need to fix some issues.
Yesterday try couple of times and this tissue not working at all.
So I guess problem solved :)2018-01-16 at 3:13 pm #1673Yuri Kovelenov
Staff2018-01-16 at 3:21 pm #1674Yuri Kovelenov
Staff2018-01-16 at 7:51 pm #1684a.gracki
CustomerOk everything corrected , can think about better materials.
One problem I notice after update to 1.0.4 is annotation Verge3D trial at the bottom right but App Manager still shows that my personal license is active
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:b8e30a08ae/applications/TT/TT.html2018-01-16 at 8:15 pm #1685a.gracki
Customerentering the KEY again solve this problem
