- This topic has 149 replies, 21 voices, and was last updated 7 months, 2 weeks ago by
as421465683.
2021-08-24 at 6:25 pm #43970
visualizer
CustomerHi
Zbwhat is wrong with my test. I tried following your guide line.
I gave position & rotation both still every time I refresh the name “css3dObj1” it shows red till I select it again. but there seems some issue still happening.I just played with your basic setup file.
https://drive.google.com/file/d/1m7Ig-ZM9uFQ4nEOsDqUndu8rMlGxWbps/view?usp=sharing2021-08-25 at 1:46 am #43975zjbcool
Customer@visualizer
1. you should open your app in a separate window, not in the puzzles editor(it’s not the final result)
2. if you don’t want to see the css3d object’s name shows red, you can use the ‘text’ puzzle instead of the ‘object selector’ puzzle, it’ll be OK.2021-08-26 at 2:08 pm #44021visualizer
CustomerHi
ZbActually I didn’t mention in previous feedback but the similar result is seen in separate window. if you want I can share screen recording of the same.
by the way… I must appreciate your response is always super fast… that’s really great !
2021-08-27 at 7:42 am #44028zjbcool
CustomerActually I didn’t mention in previous feedback but the similar result is seen in separate window. if you want I can share screen recording of the same.
really? please share the screen recording.
2021-08-28 at 8:40 am #44061visualizer
CustomerHey yes
here it is. hope its clear.
I just did it in your Css3D-Basic-Blender file.
so you can also do it real quick or I can send you file on email.2021-08-28 at 10:10 am #44064zjbcool
Customer2021-08-28 at 2:53 pm #44069visualizer
Customerhey
is it good to share files here?
just wondering.let me compare it & find out where was I wrong
2021-08-28 at 5:02 pm #44070visualizer
CustomerHi
I saw the file Thx!
So basically we have to apply the animation through puzzles only?
it can not be applied to the readily animated object in blender.. right?2021-08-29 at 4:20 pm #44074zjbcool
Customerno, you can animate in blender.
2021-08-30 at 8:35 am #44097visualizer
CustomerI noticed that mainly in your scene, there was no key frame animation.
Why it didn’t work in my scene? what was wrong.2021-09-24 at 11:32 pm #45230xeon
CustomerHi zjbcool….I ran into an issue but isolated the problem.
I am useing V3d 3.80. Blenderthe “Load YouTube Video by ID” when “enable controls” is not checked prevents the video from playing. You only get a black screen.
I really need those controls to be off.
Additionally, since this creates a plane at run time…have you been successful at parenting the created plane to a camera?
Also having an issue with Rendered sides:
Rendering – double-sided or front side it is currently only rendering double-sided.Xeon
Tutorials - https://www.xeons3dlab.com2021-09-25 at 2:05 pm #45248zjbcool
Customerhi,@xeon
I’ve updated to v3d 3.8, and the css3d plugin works well when disable “enable controls”.
also, the css3d object can parent to the camera. see the screenshot.
And yes, the “front side” rendering doesn’t work, I’ll fix it. thank you for pointing it.Attachments:
You must be logged in to view attached files.2021-09-25 at 4:05 pm #45250xeon
CustomerHi zjbcool,
Thank you for the quick response. I am using version 2.3.1 of the plugin and all seems to be working great. Thank you.Xeon
Tutorials - https://www.xeons3dlab.com2021-10-01 at 7:00 pm #45691visualizer
CustomerHi
ZBwhere can I download the updated version?
Also can css3d be linked to camrea?
that means the screen playing remains constant to viewer screen. right?2021-10-01 at 10:02 pm #45694xeon
CustomerHi Visualizer…I had the same question…you can parent it to the camera and then use the responsive controls in Verge to keep it where you want. Just keep in mind that the user has to take an action to make the video play. It will not auto play.
