- This topic has 150 replies, 22 voices, and was last updated 1 year, 3 months ago by
Alexander Kovelenov.
2021-08-02 at 12:31 pm #43378
parsecCustomerAwesome!
2021-08-03 at 7:16 pm #43411
visualizerParticipantHi
ZbCool! That’s great ! you fixed it.
I just got the new 2.3 downloaded :))
2021-08-07 at 6:23 am #43491
ZbHere I guess I see one more bug. pl check the movie clip how it responds.
https://drive.google.com/file/d/1Liv_tcCAwYavaVafnbhGNJ7fc7ZXdGHi/view?usp=sharing
When the url is brought in 3D and clicked it rotates too fast & looks weird. Other menus work normal but only the middle 360 interactive view responds weird.
the url I tested was –
https://www.toyotabharat.com/urbancruiser-360/?color=spunkyblue_blackroof&url=https://www.sharayutoyota.com/showroom/urbancruiser/#360viewRegards
2021-08-07 at 2:53 pm #43501
zjbcoolCustomerHi,
@visualizer
I don’t think it can be solved on the plugin side.
2021-08-07 at 6:05 pm #43503
visualizerParticipantAhh ok. I believe you.
I m also wondering why its happening?
Just curious… what could be the reason?For reference… developers & team this vehicle file is created in verge itself !
2021-08-07 at 7:20 pm #43506
parsecCustomer
@visualizer
Looks similar to a thing modo3d used to do if you tried to use a tablet instead of a mouse without selecting tablet in preferences.2021-08-11 at 10:54 am #43569
visualizerParticipantok..
but really wondering why this happens?
may be sensitivity factor bug? or something2021-08-11 at 11:18 am #43573
parsecCustomerok..
may be sensitivity factor bug? or somethingLooks like in that area it is getting a complete wrong position of the click, like an inherited extra angle or something similar, after all is Verge inside Verge, must be like the effect of an infinite mirror.
If you are working on both , maybe you can add an extra gui slider for rotation and “mask” that area to prevent interaction(not sure if there is a way to add a non visible mask (transparent polygon with no specular on top (maybe…?))…)..
2021-08-19 at 6:28 pm #43787
visualizerParticipantHey Zb
Is this 3 types of options possible to apply on the position animated objects in scene?
If on a click screen animated it position from A to B & works well with all three types of CSS3d behavior.
2021-08-20 at 3:06 am #43799
zjbcoolCustomerYes, you can animate the css3d object as a normal object in the v3d scene.
2021-08-20 at 7:19 pm #43880
visualizerParticipanthey
Yes it worked on position however its not working on rotation.
is it because there is specific degree mentioned in puzzles?2021-08-21 at 2:26 am #43888
zjbcoolCustomerYes it worked on position however its not working on rotation.
I released version 2.3.1, fixed the css3d object not working on rotation.
2021-08-24 at 5:45 am #43940
ZbI tested but it looks like this.
is this because there is no object name indication & selection given in puzzle editor.
earlier there was provision to select the name of object in blender.correct if I making any mistake.
2021-08-24 at 6:55 am #43944
zjbcoolCustomer@visualizer
Yes, you should specify a name for the new css3d object.2021-08-24 at 7:57 am #43948
visualizerParticipantOh
I need to check if I can really handle it.. :) -
