- This topic has 149 replies, 21 voices, and was last updated 6 months, 1 week ago by
as421465683.
2020-11-30 at 8:21 am #36078
Yuri Kovelenov
StaffYou can now embed live websites into 3D environment!
Check out the CSS3D plugin by zjbcool:
Buy on Gumroad: https://gumroad.com/l/IpdbDX
Learn how to create Verge3D plugins https://www.soft8soft.com/docs/manual/en/puzzles/Plugins.html
2020-11-30 at 11:49 am #36084zjbcool
CustomerThank you so much, Yuri!
I have updated the plugin, so you don’t need to change the Plane’s axis like in the video.
I made another video tutorial in Chinese.
https://youtu.be/BtAb0E5xiOQ2020-12-01 at 6:43 am #36121Yuri Kovelenov
Staff2020-12-12 at 6:10 am #36430zjbcool
Customer2020-12-12 at 10:20 am #36434Yuri Kovelenov
Staff2020-12-13 at 4:48 pm #36457roybell
CustomerHi Yuri, I lost my Verge serial number (do you remember me? :D) … how can I recover it? Thanks in advance!
2020-12-14 at 6:22 am #36465Yuri Kovelenov
Staff2020-12-15 at 5:43 pm #36536Marcin Klapczynski
CustomerCan you play/pause the video by just clicking on the plane? Or any other object? In your example video you click on a button above?
2020-12-15 at 7:24 pm #36539Marcin Klapczynski
CustomerI bought the addon, however can’t make it work in my scene, works only in the test scene…
2020-12-15 at 9:12 pm #36543zjbcool
Customerhi,could you send me your scene, and what 3d editor do you use?
2020-12-15 at 9:15 pm #36545zjbcool
Customerdid you apply scale before export? the plane size should be big such as 540*360
the camera setting should also be big, near/far and clip setting should set to such as 10-100002020-12-15 at 9:22 pm #36547zjbcool
you can use “when hovered” puzzle to active the css3d interaction, and use “mousedown” event to back
You must be logged in to view attached files.2020-12-16 at 4:00 am #36557Marcin Klapczynski
Customerdid you apply scale before export? the plane size should be big such as 540*360 the camera setting should also be big, near/far and clip setting should set to such as 10-10000
Thank you, I’ll tinker with that. However, resizing may not be possible as I have to fit the screen into the scene, not the other way around.
2020-12-16 at 4:06 am #36558zjbcool
Customertry make a big screen , and then scale it back using set transform puzzle
2020-12-18 at 2:24 pm #36661GLiFTeK
CustomerZj, what do you use to make your animated gifs?
