CSS how to change a nested class
Home Forums Puzzles CSS how to change a nested class
  • #66464
    huib
    Hey!
    I want to change the class assigned to the a href, inside the list item.
    In the example this is class “nav-link”
    Changing the class of the list item list-item-menu works by using the set prop puzzle.
    But how do you change the class when its one level deeper, like in this case the class of the a href doesn’t have an id on its own, so how do access it and change the class name?
    <li id="fase_01" class="list-item-menu">
                    <a href="#" class="nav-link">Fase 1</a>
    </li>
    • This topic was modified 1 year, 7 months ago by huib.
    #66469
    Use query selector to find an element by its class name
    #66475
    huib
    Thanks for the reply I don’t really understand how to implement this.
    Lets say in the example above I want to change the nav-link class.
    What puzzles would I use. Query Selector on its own would return the first result with that class name but I need only the one inside the one with id “fase_01” in this example
    #66476
    #fase_01 > .nav-link
    #66478
    huib
    Ah got it thank you! :good:
