Couldn’t export maya file to gltf
Home Forums Graphics / Maya Couldn’t export maya file to gltf
Viewing 15 posts - 1 through 15 (of 17 total)
  • #31790
    yashwanthks321
    matNodes.py line 633: No object matches name: SEAT.sheen
    in getting error like this
    #31792
    can you isolate this issue in a small Maya file that you could attach here? Thanks!
    #31793
    yashwanthks321
    it is just a sphere with ai standard surface and a simple texture which im trying to export to gltf
    #31799
    anyway, having a file would be appreciated.
    #31805
    yashwanthks321
    here is the file
    #31832
    Unfortunately, I can’t reproduce the issue with your try.mb file (tried both Maya 2019 and 2020). Also, I don’t see any SEAT.sheen object in it. Are you experiencing the same crash with this file?
    X | FB | LinkedIn
    #31834
    yashwanthks321
    whenever i use ai standard surface im facing this error and i tried a lambert it worked, the problem occures only while using ai standard surface
    #31835
    What Maya version do you have? Maybe you also have some third-party addons installed which causes that…
    X | FB | LinkedIn
    #31836
    yashwanthks321
    im using maya 2019, i just have vray plug in installed thats it
    #31837
    Try to disable V-Ray for a moment to check if the issue remains.
    X | FB | LinkedIn
    #31838
    yashwanthks321
    tried, anything with ai standard surface isnt exporting, and is giving same error
    #31841
    can you try reexporting some of Verge3D demos, such as Swiss Army Knife? Will it work for you?
    #31842
    Strange! Do you have input called Sheen in your aiStandardSurface material?
    X | FB | LinkedIn
    #31843
    yashwanthks321
    opened swiss army knife in maya tried exporting and having same issue
    #31844
    what about this?
