Copy/paste HTML, HTML DOM, CSS or javascript codes from website itself?
Home Forums Programming Copy/paste HTML, HTML DOM, CSS or javascript codes from website itself?
Viewing 12 posts - 1 through 12 (of 12 total)
  • #80677
    c4cc
    I’m trying to copy this css code< as indicated in red. I want to replicate the same exact font, especially for size, style and color:
    View post on imgur.com
    Source
    Intended font for the intended html element :
    Font for the element containing the intended element
    Yet when I copy and pasted the intended font into my visual studio code, the final font looked like this
    How do I copy/paste the desired code from into my html element so my element’s font is 100% similar? Of course, its size not intended for h1, h2 tags
    • This topic was modified 1 month ago by c4cc.
    #80699
    you could probably use the load font puzzle https://www.soft8soft.com/docs/manual/en/puzzles/Initialization.html#load_font
    #80701
    c4cc
    Thanks for the suggestion, it’s just that I wanna try copying css properties from other webpages without using puzzles.
    While those puzzles are indeed helpful I may need to learn this without puzzles
    • This reply was modified 1 month ago by c4cc.
    #80703
    Pandern
    @font-face {
      font-family: 'Founders Grotesk Regular';
      font-weight: 400;
      src: url('//forum-font.cdn.bubble.io/f1591661753437x401230189466371460/founders-grotesk-web-regular.woff');
    html {
        font-family: 'Founders Grotesk Regular', Helvetica, Arial, sans-serif !important;
        font-size: 18px;
        word-spacing: 2px;
        line-height: 1.3;
    I guess you forgot to copy/paste the source of the font, like they have in their css?
    #80704
    c4cc
    Thanks. I’ll look this up
    #80718
    c4cc
    My css
    I tried, looks like this:
    Besides color and font size, not really the same style as this:
    #80721
    Pandern
    You still need to source the font. It displays helvetica because Founders grotesk is not found.
    You can download the font by clicking on this link:
    http://forum-font.cdn.bubble.io/f1591661753437x401230189466371460/founders-grotesk-web-regular.woff
    Put it in the base folder of your project and source it like this:
    @font-face {
      font-weight: 400;
      src: url('founders-grotesk-web-regular.woff');
    you are missing quite a bit of the styling from that site. And h1 and h2 in your css might override any styling you put in .help.
    Add this to your .help
    padding: 1em 11px .25em 11px;
    line-height: 1.3;
    word-spacing: 2px;
    word-wrap: break-word;
    Try also to put your text inside a <p> tag. Like this:
    <div class="help">
      <p>
         <h1>Player Controls.....
       </p>
    </div>
    #80723
    c4cc
    I tried
    Downloaded font in base folder:
    Text inside p tags
    Where there’s improvement, the font thickness is not the same as that of the source’s?
    desired font style and thickness:
    #80732
    Pandern
    Okay, well, at least the font is correct now.
    And the text looks the same to me, except for the <h1> and <h2>, which by design are larger and thicker.
    Use only one <p> for wrapping the whole text, not each line. The <p> stands for paragraph and has system styling from the browser. Thats how it is used in the bubble site.
    Instead of trying to learn CSS by copying from a complex web site, you should maybe learn the basics of webdesign. Then you will be able to copy style from websites more easily.
    This one is a good start: https://www.freecodecamp.org/learn/2022/responsive-web-design/
    #80740
    c4cc
    Sorry, I meant to say, “While there’s improvement… ” Sorry for the typo. I was in a rush and I didn’t see it
    *facepalm
    Thanks for your advice again, Pandern, I appreciate it.
    #80835
    c4cc
    How come this element has no font-family name in?
    Source
    Thought normally font-family name is required
    Source
    #80838
    Pandern
    It does… sort of. It inherits it from html
    font is a shorthand that can set all the different properties of an element’s font:
    font: 300 15px / 1.73 'Open Sans', sans-serif;
    https://developer.mozilla.org/en-US/docs/Web/CSS/font
    • This reply was modified 4 weeks ago by Pandern.
