Home › Forums › WebGL & WebXR Troubleshooting › Converting hex to rgb for vertex colors. (Got it!)
- This topic has 7 replies, 4 voices, and was last updated 4 years ago by
indrazulfi.
2020-04-23 at 2:15 pm #26461
Xen Wildman
CustomerI realize that there is a way to input hex into the material colors but there doesn’t seem to be a clear way to set vertex color that way. I found a code snippet and added it to the JS then plugged it in to the color picker target:
app.ExternalInterface.hexToRgb = function(hex) { // Expand shorthand form (e.g. "03F") to full form (e.g. "0033FF") var shorthandRegex = /^#?([a-f\d])([a-f\d])([a-f\d])$/i; hex = hex.replace(shorthandRegex, function(m, r, g, b) { return r + r + g + g + b + b; }); var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex); return result ? { r: parseInt(result[1], 16), g: parseInt(result[2], 16), b: parseInt(result[3], 16) } : null; }
The result is not formatted in a way I can use, I need just the digits (228,60,31) or better yet linear (0.894,0.2353,0.1216)
Object { r: 228, g: 60, b: 31 } visual_logic.js:610:11
I then plug that into the math puzzles to /255. Gamma 2.2 is handled in the shader nodes.
If anyone can help I’d really appreciate input.
Edit: Or maybe if input type=”color” can output rgb.
2020-04-23 at 4:54 pm #26479Xen Wildman
CustomerI found a shorter snippet that works perfectly:
app.ExternalInterface.hexToRgb = function(hex) { return ['0x' + hex[1] + hex[2] | 0, '0x' + hex[3] + hex[4] | 0, '0x' + hex[5] + hex[6] | 0]; }
Edit: Need to check more.
2020-04-23 at 6:44 pm #26484Xen Wildman
CustomerThis is the code that ended up working for me:
function hex2rgb(hex, opacity) { var h=hex.replace('#', ''); h = h.match(new RegExp('(.{'+h.length/3+'})', 'g')); for(var i=0; i<h.length; i++) h = parseInt(h.length==1? h+h:h, 16); if (typeof opacity != 'undefined') h.push(opacity); return 'rgba('+h.join(',')+')'; }
2020-04-23 at 8:37 pm #26487Xen Wildman
CustomerHere’s the link.
2020-04-24 at 4:35 pm #26558GLiFTeK
Customerare you supposed to be able to also feed a Hex value into the sphere’s clicked prompt window that asks for RBG?
plz share Discord link & on your signature!2020-04-24 at 5:04 pm #26560Xen Wildman
CustomerNo, just the color picker in the top left. The RGB on the spheres was before I built the html with color picker.
2020-04-25 at 11:00 am #26600Yuri Kovelenov
Staff2021-03-25 at 6:04 am #39756indrazulfi
ParticipantHere’s the link.
Hi @Xen, Would you mind to explain little bit more on this ? :)
Thanks! -
