Controling objects within a loaded glTF
Home Forums Puzzles Controling objects within a loaded glTF
  • #78396
    Tom
    I’m building a large configurator and plan to split it into separate GLTF files to improve load times.
    Is it possible to select individual objects within each loaded GLTF file using puzzles?
    In the load/unload example, I noticed that I can’t select specific geometry (like a chair) with the puzzle object selector.
    For instance, if I have an environment scene that loads by default and then load a GLTF containing a teapot, cylinder, and torus, would I be able to use puzzles to select the torus and interact with it (e.g., trigger animations or change properties)?
    #78400
    possible
    #78401
    Tom
    Thanks KDV thats just what im looking for :good:
    • This reply was modified 5 months, 2 weeks ago by Tom.
    #78406
    do not use “load scene” (this puzzle will replace the main scene). use only “append scene” (this puzzle will add a scene to the main scene).
