Construction of User Interface of HTML-based 3D Web Application
Home Forums General Questions Construction of User Interface of HTML-based 3D Web Application
  • #63586
    yueyan231881306
    I used Google Web Designer to create a new .html file, nested the .html file of the Verge3D application, and created a first-person camera, but the wasd movement in the page can be used, and the mouse interaction lacks any response.
    Prompt error: on: Failed to execute ‘requestPointerLock’ on ‘Element’: Blocked pointer lock on an element because the element’s frame is sandboxed and the ‘allow-pointer-lock’ permission is not set.
    at HTMLCanvasElement.j (http://localhost:8668/applications/Exhibition_hall/v3d.js:1:1106241)
    j@v3d.js:1
    May I ask how to solve it?
    #63617
    Hi yueyan,
    We experienced lots of issues with Google Web Designer and don’t recommend it for use. You might look into the more issue-free Webflow for which we recorded tutorials.
    #63659
    yueyan231881306
    Hello, webflow is not free, some features require payment.
    #63664
    https://web.dev/sandboxed-iframes/
    #63955
    masj
    Flagging this as semi-urgent to the team. Can’t even export the code anymore from Webflow without a paid plan. People
      really
    need alternative(s) to the Webflow workflow moving forward.
