Constraint Puzzles? In next release? Its in the docs now.
Home Forums General Questions Constraint Puzzles? In next release? Its in the docs now.
  • #74627
    Just found this on in the docs
    Constraints Puzzles
    https://www.soft8soft.com/docs/manual/en/puzzles/Animation.html#constraints_puzzles_reference
    Not in my version of 4.7pre-release 1….coming in pre-release 2?
    • This topic was modified 9 months, 3 weeks ago by wpadm.
    #74630
    Hi Xeon,
    Those are already in the stable version. It’s just that they were buried deep in the docs :-)
    #74632
    So just to clarify… prerelease are not a continuation from the last stable version…. They can and do have potentially have missing functionality????
    #74633
    See Animations section and you’ll find all three constraint puzzles.
    #74634
    Yup…they are there…I was looking in physics puzzles since the puzzles in the doc are gray.
    Seems the docs are just out of date….thank you
    #74635
    Now ask them why object-related puzzles are in Animations section? I already did but the answer was a little strange )))
    #74643
    Object section was already quite big, moreover 3ds Max devs also think that animation and constraints are closely related concepts:
    3ds Max animation menu
    X | FB | LinkedIn
    #74647
    Putting them in the animation tab because of Max puts them there? Disagree with the logic of doing anything because Max does something. Not putting them in the Object group because its too big…means we need a new method to organize and select puzzles as this problem will continue to occur. Perhaps an A for add key that will bring up a search box for that you can type in the name of the puzzle or similar and dont have to go hunting for it….like Blender? LOL.
    Ok… I jest. But regardless fix the docs so the puzzles are the right color for the group you put them in. They are gray puzzles right now and had me looking in the wrong place.
    #74657
    Agreed – the search through puzzles would be helpful – working on it!
    #74852
    visualizer
    True!
    Search facility through puzzles would be a great addition.
    Also is there any chance of including the facility to check which category the current puzzle is from? Instead of just colors.
    May be a tiny marker clicking on which will tell user where this puzzle is located in the huge list of categories.
