Console errors MIME + SketchUp API
Home Forums WebGL & WebXR Troubleshooting Console errors MIME + SketchUp API
  • #31370
    abin
    “Refused to apply style from ‘url’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.”
    this msg i have on server side, I researched the net but everybody says something else….If somebody had this and solved it, please tell me.
    I have integrated a player von sketchup in my annotation, which works good local. But on my server side I get this:
    “DevTools failed to load SourceMap: Could not load content for https://static.sketchfab.com/static/builds/web/dist/npm.getstream-cd062b73407a206b1c84a9faa0605f01.js.map: HTTP error: status code 403, net::ERR_HTTP_RESPONSE_CODE_FAILURE”. and this: “you are using a deprecated api, please update to the new one, read mode xxxx”
    #31371
    abin
    So I solved the MIME problem as follows (this error was only present in chrome):
    <link rel=”stylesheet” type=”text/css” href=”/my-style.css”>
    was without “/” in path, which didn’t work on my server
    #31378
    thanks for sharing your solution! :good:
