Configurator with multiple colors on one object
Home Forums General Questions Configurator with multiple colors on one object
  • #27464
    Anonymous
    Inactive
    Basically I need to break a wheel down into it customizable parts. This means sides of spokes can be their own color etc. I’m working with a 3d designer who works in solidworks and when I bring the STL file into blender the mesh is all over the place making it almost impossible to select faces and export them individually. Do I need to look into 3ds max? Or is there a way he could color each face a specific color and then use puzzles to differentiate the faces and change them accordingly?
    #27468
    GLiFTeK
    This is something of interest to me as well. Though this suggestion doesn’t help on the blender side of things like you’re asking, it may have potential.
    Verge3D is capable of using this STL loader …
    verge3D STL Loader Example Demo
    Verge 3d git repository STL loader code
    You could have that worked into your app, and use code to distinguish targeted areas for coloring.
    This kind of method is something I’m just learning to do now though.
    Word of advice on importing STL files into blender, in the import/open file dialogue window, use the axis changing option, as blender uses Z for “up” and STL I believe, uses Y as “up”.
    There are free STL conversion apps or there that may help put things in more useful order.
    #27473
    You can use a complex system of mask to color different parts with different colors, but better to divide one object into separate objects.
