Home › Forums › Graphics / Blender › Combine XYZ and Value node for transparent procedural emission?
- This topic has 17 replies, 2 voices, and was last updated 1 year, 5 months ago by
c4cc.
2023-10-09 at 4:56 pm #67417
c4cc
ParticipantI’m trying to use these CombineXYZ and Value nodes for transparency and emission, especially for the black part of “sphere”. My file
Yet when I checked out sneak peak, this sphere is black. I don’t think it’s an issue of material node compatibility, as Xeon says here, “Attach a combine xyz node to transparent and emission nodes and then create value nodes as inputs to the xyz node”.
So how do I use Combine XYZ nodes and Value nodes to make both slight invisibility, and to give emission color as it appears in blender?
2023-10-10 at 12:25 am #67424kdv
ParticipantTransparent BSDF
is partially supported. The color should be pure white.
https://www.soft8soft.com/docs/manual/en/blender/Shader-Nodes-Reference.html#Transparent_BSDFPuzzles and JS coding. Fast and expensive.
2023-10-10 at 3:32 am #67429c4cc
Participant2023-10-10 at 4:23 am #67430kdv
Participantthis sphere is black
This is the black color. A sphere colored with black is black?
2023-10-10 at 6:29 am #67432c4cc
Participant2023-10-10 at 7:13 am #67433kdv
Participant2023-10-10 at 9:44 am #67439c4cc
ParticipantWhile your solution does work, from sneak peek, why does my sphere disappear when I view it from below?
2023-10-10 at 5:44 pm #67456kdv
ParticipantLooks like a simple far clipping of the scene’s camera.
2023-10-10 at 10:59 pm #67458c4cc
So how do I prevent this, using your mix emission with transparent?
2023-10-10 at 11:01 pm #67459kdv
Participant*facepalm*
Show that file…
2023-10-11 at 12:53 am #67460c4cc
ParticipantHere it is. In Blender and browser, the “core” is visible from certain 90 degrees angles, but I view from different angle and it goes missing. I’d like to be able to view both the core and the sphere regardless of angle and camera range
2023-10-11 at 1:12 am #67463kdv
Participantwhy does my sphere disappear when I view it from below?
Increase far clipping distance
Set
Render order
for the core to 1
Or enable Order-Independent Transparency rendering.
Or place the core exactly at the center of the sphere.
2023-10-11 at 3:45 am #67466c4cc
ParticipantThanks, your advice here worked. Time to apply this
2023-10-11 at 5:46 am #67467c4cc
ParticipantAlso, if I want to change the emission color in browser, do I use Combine XYZ and Value nodes, as per Xeon mentioned? Or is there a simpler alternative just as effective?
2023-10-11 at 6:31 am #67468kdv
ParticipantTry and see.
