Colored Transparency Node
Home Forums Bug Reports and Feature Requests Colored Transparency Node
  • #14688
    illussimo
    Verge3D 2.12
    Color input is now supported for the Transparency BSDF node
    Unfortunately, that doesn’t work. It did work in former versions. Now, I have to put the Transparency Node to white to get transparency working again. This is for Blender 2.79 I haven’t tried the new built of 2.8 yet. :unsure:
    #14689
    we did it to match Blender 2.80 behavior since the Color input is converted to grayscale in Blender EEVEE. You can use color in the non-transparent shader to make it look as before.
    X | FB | LinkedIn
    #14704
    illussimo
    So the transparency node is supported for grayscale but not for colour.
    That was not so clear in the description:
    I had a mix shader with diffuse colour and Transparent colour in Blender 2.79. I have set the transparent colour to white and strengthened the diffuse colour a bit so it works well now.
    I tried the new Built of Blender 2.8 the transparency node works well. I think it’s nearly time to make the full switch. The 2.8 built of today is truly awesome, a lot of issues (with weight painting and so on) of last week have been fixed and the new interface changes are fantastic! :yahoo:
    I understand that consitancey with the Eevee nodes are of most importance now.
    Thanks for your quick reply,
    :bye:
