Color change issue
Home Forums General Questions Color change issue
  • #15968
    dragosburian
    Hello, we are using the code the ‘set color’ puzzle generates, but on some color variants we get different color shades(either less saturated or even the wrong color)- see attached image. Any idea how to get a better color match, or is this something planned for an update? Thank you!
    #15970
    Hello,
    Colors seen in an HTML-based color picker are in sRGB space while in 3D the colors are in linear space. To make them match you can use these API methods:
    convertLinearToSRGB()
    convertSRGBToLinear()
    https://www.soft8soft.com/docs/api/en/math/Color.html
    #15972
    dragosburian
    Thank you, Yuri!
    #15983
    yasse
    @dragosburian, @Yuri. thank you for the topic, that was also my request two days ago, i’m still having issue to figure a way to implement this using javascript/ and math function. I’m just wondering if you had it implemented in a small sample file to share please ? I Will be so thankful.
