clone of object in verge
Home Forums General Questions clone of object in verge
  • #65017
    visualizer
    I see we can make clone of the objects in verge by using the puzzle clone.
    What I noticed is,
    if I clone a fan rotating with ‘x’ speed then fan gets duplicated but the rotation is not applied to clone.
    Clone remain still while the original is rotating.
    any clue to fix this?
    • This topic was modified 1 year, 9 months ago by visualizer.
    #65027
    Hi, in appears to be the correct behavior. How rotation to the original object was applied?
    X | FB | LinkedIn
    #65030
    visualizer
    It is key in blender on time line as usual. But not baked. Hope this gives clarity to you.
    check the screen record first set of puzzle is okey to clone object at some x..y.z position but how do I apply that motion of object1 to cloned object2?
    • This reply was modified 1 year, 9 months ago by visualizer.
    #65036
    visualizer
    Just thinking
    do we need a puzzle which allows to
    copy animation from “xxx” to “xxx” ? &
    then some additions like from range xx to xx , loop, reverse, once, pingpong etc.
    #65037
    Animating cloned objects
