Home › Forums › General Questions › Clone object by HTML input
- This topic has 20 replies, 2 voices, and was last updated 2 years, 2 months ago by
Marko.
2023-09-07 at 9:57 am #66647
Marko
CustomerHello,
how to clone object acording to input value on external html?
For example, if I have beam
(dimensions for example: width: 0,1m; length: 1m; height 0,5m)
i want clone that beam specified by inserted number (html input id=”beamNumber”)
upon “z” os, (by beam heigth).After that – It must also be possible to define the distance between cloned objects in the second “input” window. (html input id=”distanceClone”). So we can specify the spacing value between the cloned objects.
Here is similar “input” example from forum but no puzzle to help: https://sandbox.soft8soft.com/product/drink-variable/
I would be grateful if someone could give me an example via a puzzle of how to arrange it.
Thank you!
2023-09-07 at 5:18 pm #66660kdv
2023-09-08 at 6:07 am #66672Marko
CustomerDear “kdv”,
thank you very much for your effort. Unfortunately, it doesn’t work for me. I did everything like you but nothing happens. I switched the “input” elements inside the Iframe, (otherwise the “in parent doc” check box must be checked), but even then it doesn’t work. I tried some other combinations with this but it doesn’t work.
I’m attaching a picture where you can see the html code, so maybe I didn’t define something well. It would be good if you could put your project in “zip” so I can compare.
In any case, many thanks for your time and help.
2023-09-08 at 6:33 am #66676kdv
ParticipantSee the console log first. Use the
print to consolepuzzle for debugging to monitor every step. Do not be a blind coder, use debugging.Puzzles and JS coding. Fast and expensive.
2023-09-08 at 6:46 am #66677Marko
CustomerSorry, I’m new to coding and I don’t know how to use “print to console”
My Chrome console don’t show any problems.2023-09-08 at 6:51 am #66678kdv
ParticipantSomething like this. Read variables. All of them must be defined.
2023-09-08 at 7:19 am #66681kdv
ParticipantBTW, what’s the height of your beam? You are using 5 as an interval. That is, for a second, 5 meters.
2023-09-08 at 7:24 am #66682Marko
CustomerYes. I’s so long. This is only example, original will be similar.
Btw: In link is my project so you can export in your applications folder.
https://www.dropbox.com/scl/fi/p3vaigcmoxmw1i4ea4h8w/Ograda.rar?rlkey=ml0sucs0swz3h66wu7cc6ko0m&dl=0I wouldn’t take more of your time, I’m sending this if you’re also interested in how to make it.
Thank you for all.
2023-09-08 at 7:43 am #66685kdv
ParticipantОграда? Для огорода? )))
Here’s you mistake. There is no element with the class name
submit_buttonin your html file.
Should be this way
2023-09-08 at 7:52 am #66689Marko
CustomerIncredibly!! I’m really blind! :) Works perfectly!
“Ograda” is actually the croatian name for “fence”.You are my savior.
I want buy you a drink :) Send me paypal email.Thank you!!
2023-09-08 at 7:58 am #66690kdv
ParticipantI want buy you a drink :) Send me paypal email.
Contact me via e-mail kdv [at] izh [dot] com and I’ll send you PP account.
2023-09-08 at 8:04 am #66691Marko
CustomerYou have email.
2023-09-18 at 6:37 am #66889Marko
CustomerHello. One additional question. Is it possible to clone the object according to the Z and Y axes? Or how to simulate the cloning of clones? I know that you cannot clone a group of objects, but I need to be able to clone the same object upwards and to the right.
2023-09-18 at 6:48 am #66890kdv
Participantuse an additional loop to clone along another axis inside the first loop
2023-09-18 at 6:57 am #66891Marko
CustomerIt’s not that simple beacuse it’s the same project where I have the “input” of default parameters. If I insert a loop in that part, only the bottom row along the Y axis is cloned, but not the Z axis.
What I need to get is this from the attachment.Attachments:
