Clipping Planes material texture?
Home Forums General Questions Clipping Planes material texture?
  • #49371
    Micdsn
    I’m loving Verge3D! With the clipping Planes feature–can we assign a mapped texture to the cross section or only a solid color? It would be amazing if I could make it a specific map…! Thank you!
    #49390
    You can make you own custom clipping plane fill, but only if you are blender user. Here’s an example
    #49395
    Micdsn
    Thanks for the answer–I set up my object with a back face like yours and I can look in Blender and verify the back face is chenged, but it does not affect my scene when clipping. I’ve tried all the options in the clipping plane properties and nothing seems to work. ‘filled cross section’, ‘render side’ and even making the cross section color transparent.. what do you think?
    #49402
    You need to disable filled cross section and use doulbe-sided material.
    #49425
    Micdsn
    Following up: I had ‘gltf 2.0 compatible’ turned on, and this was preventing it from working. I turned it off and it works now!
    #49439
    :good:
