Clipping plane transparency bug
Home Forums Bug Reports and Feature Requests Clipping plane transparency bug
  • #48878
    Bignatov
    Interactive clickable objects visible behind a clipping plane do not work. It seems to be a bug because sometimes the objects do work but it happens after many clicks on them. Hiding the clipping plane in puzzels does not help.
    #48912
    We’d appreciate if you attached a simplistic project that reproduces this issue. Thanks!
    #48921
    Bignatov
    Here is an example. I have put it on your server for you to take a look at the files. When you click on the cabinet doors they work only sometimes.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:6adffc3a05/applications/1%20Caravan%20New/1%20Caravan%20New.html
    #48933
    I understand. The thing is that the cut-out plane removes parts of the model from rendering, but not from raycasting performed by mouse pointer.
    I’d recommend to remove the front side of the model so that it allows for free clicking.
    #49091
    Bignatov
    I see what you are saying, but the whole beauty of the clipping planes is that they can be dragged in real-time to see different sections of the model. Please keep in mind this issue for the next update. It will be great to cut a model and click inside it.
    #49122
    thanks for bringing this up!
