Clipping-Plane: Change material of backside
Home Forums Graphics / Maya Clipping-Plane: Change material of backside
  • This topic has 1 reply, 2 voices, and was last updated 2 years ago by kdv.
  • #60172
    gingerbreadman
    Is it possible to cover the back of the clipping-plane with a certain material instead of making it completely invisible? I haven’t seen an option in maya or puzzles.
    Best Regards
    #60179
    What do you mean? A clipping plane itself is always invisible. The cross-section mesh cannot be visible trough the opaque intersected mesh. So what exactly do you want to see in the place of intersection?
    If the intersected object is semi-transparent then you can make the cross-section material double-sided and it will be always visible.
    https://v3d.net/eut
