Home › Forums › Graphics / Blender › Clicking “THROUGH” geometry?
- This topic has 14 replies, 3 voices, and was last updated 4 years, 10 months ago by
GLiFTeK.
2020-04-20 at 5:34 am #26076
GLiFTeK
Customerhi
i have some geometry that’s interactive (mouse clickable) that’s WITHIN some other geometry ( an “overlay graphic” cylinder ) that surrounds it.I’ve made that outer cylinder object that blocks the cliks object be “unselectable” in blender in object properties panel.
is there something else similarly simple to do to make sure this doesn’t interfere in my inner objects receiving their click or do i have to do a ]sic] “pointer event = none” type css for any object that shouldn’t get clicks?thanks.
EDIT: i made a list of all objects “UNCLICKABLE_objects” i wanted to be unclickable.
I made a css rule :.unclickable{ pointer-events: none; }
I made an HTML puzzle set att className to “unclickable” for element “UNCLICKABLE_objects”
not making a difference. guess that doesn’t affect webgl elements…?
plz share Discord link & on your signature!2020-04-20 at 7:57 am #26120Yuri Kovelenov
StaffHi,
You can check if a picked object is in the list of clickables (or NOT in the list of unclickables)
https://www.soft8soft.com/docs/manual/en/puzzles/Lists.html#find
https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#get_objects_from2020-04-20 at 8:10 am #26125Yuri Kovelenov
Staff2020-04-20 at 8:13 am #26126GLiFTeK
CustomerOk thanks, Yuri.
I’ll try that.
Hope it lets me “through”Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-04-20 at 9:34 am #26141GLiFTeK
CustomerIf you mean the internal object is obscured and thus cannot be clicked, then you can use another transparent object which will receive clicks instead.
oh i didn’t see that second response.
yes i’m trying to click THROUGH an object’s geometry which is a barrier to my clicks.
the clickable objects are INSIDE the cylinder overlay (semi-transparent)hmm yeah having a double hitbox for them wouldn’t work.
plz share Discord link & on your signature!2020-04-20 at 9:38 am #26142GLiFTeK
could i use rendering order to have them “be” in their certain location in 3d, but have a different css z-index ?
don’t know if that translates to webgl tho.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-04-21 at 6:34 am #26212Yuri Kovelenov
Staff2020-04-21 at 11:46 pm #26312GLiFTeK
CustomerAlas, the only way to go is implement your own object picking feature with JavaScript.
yeah, just want the cursor to never interact with the containing overlay cylinder.
only with objects inside it. (which, can be viewed from any angle…)sure there’s a method for that buried in the dev pages… (whips out giant shovel) ..
plz share Discord link & on your signature!2020-04-22 at 8:18 am #26333Ivan Lyubovnikov
Staffsure there’s a method for that buried in the dev pages… (whips out giant shovel) ..
If you’re using the “when clicked” puzzle for selecting objects in the scene, then there’s a little js hack to change the way their selection is managed.
Internally “when clicked” uses raycasting, also there’s an API method Object3D.raycast which is used for testing if an object is picked by a raycaster.
So, if you know an object’s name you can disable it from being selected as follows:
var myObj = app.scene.getObjectByName('myObj'); myObj.raycast = function() {};
And make it selectable again like this:
var myObj = app.scene.getObjectByName('myObj'); delete myObj.raycast;
Edit: forgot to mention that the
app
variable in the examples above is the same that you have in the standardrunCode
function in an application’s js file.Co-founder and lead developer at Soft8Soft.
2020-04-22 at 10:18 am #26350GLiFTeK
CustomerWow. Super cool.
Will try it!
Thnx!Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-04-22 at 11:30 pm #26406GLiFTeK
CustomerHI,
QUESTION,
i have it working on single objects.
curious as to wondering the reason why the top procedure won’t work and the bottom does here…here’s my changed code
app.ExternalInterface.setUnclickable = function (unclickable) { var myObj = app.scene.getObjectByName(unclickable); myObj.raycast = function() {}; console.log("UNCLICKABLE: ", unclickable); }
thnx
plz share Discord link & on your signature!2020-04-23 at 7:49 am #26438Ivan Lyubovnikov
Staffcurious as to wondering the reason why the top procedure won’t work and the bottom does
That’s because “get all objects from” already returns a list. I think it should work if you just plug it directly into the LIST_* variable.
2020-04-23 at 8:05 am #26439GLiFTeK
Customercurious as to wondering the reason why the top procedure won’t work and the bottom does
That’s what I initially did.
My console log print of the LIST_ item when it’s made using those puzzles reads “Array (2)… “GROUP” and “Cylinder_Light_Collection” , which aren’t able to expand. So no contents just strings.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-04-23 at 8:47 am #26445Ivan Lyubovnikov
StaffMy console log print of the LIST_ item when it’s made using those puzzles reads “Array (2)… “GROUP” and “Cylinder_Light_Collection” , which aren’t able to expand.
Oh, I guess you tried a puzzles setup that looks like this:
“set LIST…” <-> “Cylinders_Light_Collection”I actually meant that you can just drop the “create list” puzzle:
“set LIST…” <-> “get all objects from” <-> “Cylinders_Light_Collection”– have you tried that?
2020-04-24 at 6:28 am #26497GLiFTeK
CustomerMy god…lol..
I HAD THAT… But after that, I combined that and another array(list) into one big list of unclickables. Guess I’ll just make them all be in one collection in blenderBut yea for one group (not combined groups/multiple arrays in one) that works. Alrighty Then!
Thnx
