Clicking camera movement in first-person mode
Home Forums Puzzles Clicking camera movement in first-person mode
  • #47115
    sireon
    Hello. How to implement camera movement by click in First-Person mode? On the computer by default – WASD, I would like the character to move by mouse click or tap (on touch-screen devices). I would also like the camera to keep looking where it was looking before it was moved.
    #47154
    sireon
    Implemented as follows. The only thing I could not implement a smooth movement of the camera from point A to click point. There is a node “tween camera to”. But I don’t understand what to put in “look at” input.
    #47162
    The “look at” parameter specifies a 3d point where the camera should look at after the movement is done. If you want to keep the camera’s orientation the same then you can calculate the “look at” parameter by adding together the camera’s current direction/orientation vector and the new position to move to.
    I attached a test demo, where you can look around via the left mouse button and move by clicking the plane with the right mouse button.
    Hope this helps!
    #47197
    sireon
    Hope this helps!
    Thank you!
    #48562
    AVerge3Der
    This is great. Thank you for sharing Ivan.
    (Future self->See the example project in the above post)
    (Mouse right-click and move the camera to that spot sample code) :yahoo:
    #63692
    niklasber
    How can I open your attached zip file in verge3d? So I can have a look on the code blocks.
    #63856
    Hi, you can unpack it manually into Verge3D’s applications directory. After that it should appear in the project list in the App Manager. Then you can open it in the Puzzles Editor and check the code blocks.
