Home › Forums › Graphics / Blender › Click through/click beyond a transparent image
- This topic has 8 replies, 4 voices, and was last updated 3 years ago by
Артём.
2020-12-16 at 3:37 pm #36611
Johnson
CustomerHi Soft8Soft!
I have a transparent image attached to the camera in my scene so that it’s visible no matter where the user turns, and wanted to click beyond that transparent image– to be able to click on to textures, on to planes, geometry, etc.
How would I do that?
2020-12-16 at 5:10 pm #36614GLiFTeK
CustomerUse a. Call JS puzzle.
MAKING OBJECTS “UNCLICKABLE”
many times you need to click “through” an object.
This is how:"app.ExternalInterface.setUnclickable = function (unclickable) { var myObj = app.scene.getObjectByName(unclickable); myObj.raycast = function() {}; console.log("UNCLICKABLE: ", unclickable); };" And make it selectable again like this: var myObj = app.scene.getObjectByName('clickable'); delete myObj.raycast;
where “unclickable” is where you plug in your object selector or variable that has that as it’s value.
You can also use the execute js puzzle
plz share Discord link & on your signature!2020-12-17 at 1:02 pm #36629Johnson
CustomerUse a. Call JS puzzle. MAKING OBJECTS “UNCLICKABLE” many times you need to click “through” an object. This is how:
<span class=”crayon-title”></span><textarea wrap=”soft” class=”crayon-plain print-no” data-settings=”dblclick” readonly=”” style=”tab-size: 4; font-size: 12px !important; line-height: 15px !important; z-index: 0; opacity: 0; overflow: hidden;”>
“app.ExternalInterface.setUnclickable = function (unclickable) {
console.log(“UNCLICKABLE: “, unclickable);
};”And make it selectable again like this:
var myObj = app.scene.getObjectByName(‘clickable’);
delete myObj.raycast;</textarea><table class=”crayon-table” style=””><tbody><tr class=”crayon-row”><td class=”crayon-nums ” data-settings=”show”>12345678910</td><td class=”crayon-code”>
<span class=”crayon-s”>”app.ExternalInterface.setUnclickable = function (unclickable) { </span><span class=”crayon-s”> var myObj = app.scene.getObjectByName(unclickable);</span><span class=”crayon-s”> myObj.raycast = function() {};</span><span class=”crayon-s”> console.log(“</span><span class=”crayon-v”>UNCLICKABLE</span><span class=”crayon-o”>:</span><span class=”crayon-h”> </span><span class=”crayon-s”>”, unclickable);</span><span class=”crayon-s”> };”</span><span class=”crayon-st”>And</span><span class=”crayon-h”> </span><span class=”crayon-e”>make </span><span class=”crayon-e”>it </span><span class=”crayon-e”>selectable </span><span class=”crayon-e”>again </span><span class=”crayon-e”>like </span><span class=”crayon-r”>this</span><span class=”crayon-o”>:</span><span class=”crayon-h”> </span><span class=”crayon-t”>var</span><span class=”crayon-h”> </span><span class=”crayon-v”>myObj</span><span class=”crayon-h”> </span><span class=”crayon-o”>=</span><span class=”crayon-h”> </span><span class=”crayon-v”>app</span><span class=”crayon-sy”>.</span><span class=”crayon-v”>scene</span><span class=”crayon-sy”>.</span><span class=”crayon-e”>getObjectByName</span><span class=”crayon-sy”>(</span><span class=”crayon-s”>’clickable'</span><span class=”crayon-sy”>)</span><span class=”crayon-sy”>;</span><span class=”crayon-h”> </span><span class=”crayon-e”>delete </span><span class=”crayon-v”>myObj</span><span class=”crayon-sy”>.</span><span class=”crayon-v”>raycast</span><span class=”crayon-sy”>;</span></td></tr></tbody></table>
You can also use the execute js puzzleThank you Gliftek! Really appreciate your clarification.
Only problem is, I really don’t know what I’m doing when it comes to javascript and placing it into puzzles (still trying to learn!), is there anyway you could show me exactly what the code is that I’m putting in the execute js puzzle or upload a puzzle with that code in when my object is called “lens1”?
2020-12-17 at 1:23 pm #36630Yuri Kovelenov
Staff2020-12-17 at 4:53 pm #36635GLiFTeK
CustomerO dayum.. I’m old school. Hahaha.
Totally forgot about this new feature.
Super cool.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-12-17 at 7:43 pm #36638Johnson
CustomerThank you Gliftek for the previous insight.
Thank you for that example in 3.5 Yuri, that worked perfectly! Appreciate the answer, thank you!
But now I can’t use the “when hovered” puzzle to change the cursor on other elements for some reason, do you know the cause of that?
2020-12-18 at 7:11 am #36649Yuri Kovelenov
Staffplease see this answer https://www.soft8soft.com/topic/change-cursor-in-hover/
2020-12-18 at 1:36 pm #36659Johnson
CustomerThank you Yuri!
2022-02-10 at 10:57 pm #49342Артём
CustomerIn version 3.5, Verge3D’s when clicked puzzle obtain the option x-ray. If enabled, it allows to interact with objects overlapped by other objects.
thanks! It helped with the case when the UI from the blender used and when the object was as close to the camera as possible, the buttons lost their functionality. The x-ray checkbox helped!
