Changing Camera Controls Corrupts Mouse Wheel
Home Forums Programming Changing Camera Controls Corrupts Mouse Wheel
  • #52699
    wishful97
    Hello all,
    Question in short:
    Why mouse wheel zooming gets corrupted after changing controls?
    Longer Description:
    I have a simple scene (which I attached to this post) with orbit controls at the beginning and mouse wheel scroll works fine for zooming.
    I also have a red button on top left that on click, toggles the camera controls between FirstPerson and Orbit. When I click it once and switch to FirstPerson, the mouse wheel does not zoom correctly (but the w button works fine for zooming) and it jitters and jumps as you can see in the attached video. After that even if I click on the red button to change the controls back to Orbit, mouse wheel does not work correctly.
    video
    #52740
    see below…
    #52741
    function runCode(app) {
        // add your code here, e.g. console.log('Hello, World!');
        var isFP = false;
        var prevControls = app.controls; //save OrbitControls with all parameters
        $("#change_control").click( function() {
            console.log("controls changed");
            if (isFP) {
                app.controls = prevControls;
                app.controls.enabled = true; //enable OrbitControls
            else {
                app.controls.enabled = false; //disable OrbitControls
                app.controls = new v3d.FirstPersonControls(app.camera, app.renderer.domElement);
                //app.controls.zoomSpeed = 0; //disable wheel zoom
            isFP = !isFP;
    that’s because Orbit and FirstPerson controls were both active )))
    #52767
    wishful97
    Thank you very much for your time and help!
