Changing base color using HTML color code
Home Forums Programming Changing base color using HTML color code
Viewing 8 posts - 16 through 23 (of 23 total)
  • #7877
    dragosburian
    By name you mean the python name it show when you hover the cursor over the rgb node?
    #7879
    I marked it with green in the screenshot I posted earlier.
    #7880
    dragosburian
    Thank you Yuri, I will check it out later.
    #7884
    dragosburian
    Unfortunately it doesn’t seem to work. Here is my setup:
    #7890
    Hi dragosburian,
    You need to add the following line right after applying the new color, it should update the material to display the changes:
    mat.needsUpdate = true;
    #7892
    dragosburian
    Thank you guys! It work now. Cheers!
    #20301
    lamthanhle
    Hi Yuri,
    This code alway return 0,0,0
    hex = Math.floor(hex);
    var x = (hex >> 16 & 255) / 255;
    var y = (hex >> 8 & 255) / 255;
    var z = (hex & 255) / 255;
    color = new Vector4(x,y,z,1.0)
    :wacko: :wacko: :wacko:
    #20310
    this code assumes that you supply a hexadecimal number
    See here for converting a textual value
    https://stackoverflow.com/questions/5623838/rgb-to-hex-and-hex-to-rgb
