Change Verge3D Animation settings for multiple instances
Home Forums Graphics / Blender Change Verge3D Animation settings for multiple instances
  • #32150
    shantiscript
    Hy I have a collection that consist of multiple Hierachies that have different animations nested inside of them.
    I would like to change the export animation settings for all nested animations to only play once instead of the default repeat mode.
    If i select all animations either via select hierachy or selected all objects the changes in the animation settings won’t be applied to all animations within the collection but only to the selected one.
    I need to select every animation and change the setting, and there are a lot of them. Is there a way to change the settings for all animations nested inside of a collection?
    #32151
    shantiscript
    Another quesiton. Is it possible to change the animation settings globally for the whole export? I want to trigger all animations through code in the end and would like to dissable on all animations on start for export. But have the ability to also turn all of them on easily for the purpose of building and testing
    #32152
    shantiscript
    hi I allready found an answer myself:
    https://stackoverflow.com/questions/16625969/how-do-i-change-the-same-parameter-on-multiple-objects-efficiently-in-blender
    copy to selected is the magical command.
    Still would be courius about las question. Can i change all settings for export globaly?
    #32157
    you can hold Shift key and click on a checkbox to apply it for all selected objects in Blender.
