change product color via WooCommerce color picker
Home Forums Programming change product color via WooCommerce color picker
  • #46087
    robertdrost
    Hey everyone,
    we have a product in WooCommerce that can be painted in any color.
    Customers can use a color picker to select a color on the product page in WooCommerce.
    The product should then be displayed in the selected color in the verge3D iframe.
    What would be the best way to send the color to verge3D?
    Thank you very much!
    Robert
    #46098
    Well, like all things, there are many ways to do this and it will depend on your personal preferences as to the best approach.
    A simple way is to use the HTML “onEvent mouseup” and then use this in combination with the HTML “get prop value” and then move the value within the puzzles in a puzzle variable.
    You could use javascript, files, whatever you like. You could even have the color picker inside the verge app and not worry about passing the variable.
    #46099
    haris
    I can help you to solve this problem contact me on Gmail harisimran1012@gmail.com
    #46430
    robertdrost
    Thanks @xeon !
    It worked the way you described it. Now that we know, how to get puzzle variables from external sources, the rest is easy. :good:
