change origin for cloned object
Home Forums General Questions change origin for cloned object
  • #72165
    Lee
    Is there a way for changing the origin of the object which is clonned in the puzzle dynamically?
    Imaging you have an object of a curtain with the animation and it shrinks and expands by changing its scale from its own origin(top left side corner).
    And when you have a clonned object for it, it is supposed to shrinks and expands as well but from the symmetry origin(top right side corner) so that it scales from it as we expect to see the two curtains open to the left and right side each.
    I couldn’t find any relevant puzzle for handing origins.
    Anyone has tips for this issue?
    #72166
    it’s possible in three.js, but you’ll have to manipulate an object’s geometry via JS (translate, rotate or scale).
    in your case just try to change scale to -1. this will mirror an object along the chosen axis. and one more thing: using standard puzzles won’t allow you to clone objects with animations. cloned objects will be static meshes.
    #72186
    Lee
    You are a GURU of Verge3D, Kdv.
    Thanks for giving us great solution as always.
    I will get cloned objects applied the animation again then.
    What a nice tip!
