Cast shadows vanish when I switch cameras
Home Forums General Questions Cast shadows vanish when I switch cameras
  • #33191
    johngrigni
    Is there a setting I’m missing? The main camera in the scene swoops down into a specific area, then switches to the local camera (with more restrictions and slower movement due to scale), but the cast shadows disappear when the camera switches, the reappear whenever it switches back to the main camera.
    You can see it here: https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:d4c42d0559/applications/Carboline/index.html
    #33244
    Hi John,
    a likely reason is that your second camera’s far/near distance may be too close to each other, making the shadow volume smaller and shadows cut out.
    Just a guess!
    #33264
    Hi John,
    The Clip End value on the second camera in your scene is 1000, try to change it to 100, that should help.
    #33273
    johngrigni
    Thank you! That solved it!
