can`t submit my daily jobs to our Renderfarm if Verge3D is installed
Home Forums Bug Reports and Feature Requests can`t submit my daily jobs to our Renderfarm if Verge3D is installed
  • #35045
    organics
    We are currently testing a new pipeline for us
    and came across Verge3D and 3D StudioMax 2021.
    I’m doing test projects right now and I’m already very satisfied,
    but I have an annoying problem.
    As soon as I have installed Verge3D, I can’t send jobs to our render farm via Deadline.
    At the moment I always have to uninstall Verge3d to render current projects and whenever I want to continue testing with Verge3d I reinstall Verge3d.
    I’ve already tested installing the plugin on the farm but it doesn’t change anything.
    Deadline always shows a plugin error, even if the project has nothing to do with Verge3d
    Is there a workaround for this?
    Thanks a lot
    #35063
    web
    This is because of the verge params which getting added for every object created by default. To fix this you can uncheck “auto assign …” in the verge3d dropdown.
    In order to remove these params in a already “present” scene. You can go to “Utilities” -> “Max Script” -> “Verge3D”. There you have the option to delete all verge params. Just select all objects in the scene and click the “remove verge3d params” button.
    #35311
    organics
    Wonderful it works thanks a lot !!! :yahoo:
