Can’t separate 2 objects
Home Forums General Questions Can’t separate 2 objects
  • #41125
    L.H C.T
    Hi there
    Currently, I have 2 objects v.26 and v.187
    I want to double click the left mouse button, then v.187 must be transparent with a set value of 0.5. However, if I click twice on v.187 and then again click on v.26 object, v.26 is immediately hidden
    As far as I understand it is still not able to separate the 2 objects when controlling
    Can someone show me how these 2 objects are completely independent?
    Thanks
    #41127
    You need to make for them independent counters viriable.
    #41128
    L.H C.T
    that’s a good idea. but i don’t know how to do it, can you give more instructions. What if I do it for 20 objects?
    #41130
    Just create click_encounter_1 then click_encounter_2 and etc till 20, you can do it in variable section of puzzles in left panel.
    #41131
    L.H C.T
    Thanks for your help.
