Home › Forums › General Questions › Can’t move duplicated armature/mesh
- This topic has 7 replies, 2 voices, and was last updated 2 years, 3 months ago by
kdv.
2024-06-17 at 3:38 pm #74914
sbs
ParticipantHi All,
I’m trying to clone an armature/mesh but I can’t get it move anywhere once I have done this, I can see it creates a duplicate but nothing can be done with it, I have tried cloning the armature and mesh individually as well as together
Or is there a way to move a mesh independently to its parented armature?
Excuse my ignorance if this is something very obvious
Any help would be much appreciated
2024-06-17 at 6:27 pm #74915kdv
ParticipantThis puzzle can properly clone armatured meshes and those meshes can be moved freely.
2024-06-18 at 9:01 am #74927sbs
ParticipantI see its part of a bundle, any chance I could buy just that puzzle from you? I don’t really need the others and can’t afford the whole bundle at the moment
2024-06-18 at 11:38 am #74929kdv
Participantfree hint: clone an armature (its skinned mesh will be cloned as well). move the armature, not the skinned mesh which by default is attached to its armature and cannot be moved. the only problem is that the cloned skinned mesh will have the same name as its original and you’ll have to rename it.
2024-06-18 at 2:21 pm #74939sbs
ParticipantThank you, I did notice that it creates a duplicated skinned mesh with the same name.
When I move the duplicated armature should it also move the mesh connected to it or will it not because it has the same name?
2024-06-18 at 2:36 pm #74940kdv
ParticipantWhen I move the duplicated armature should it also move the mesh connected to it
Yes.
The problem will appear if you try to use dragging. In this case names of cloned meshes will matter.
2024-06-19 at 10:34 am #75024sbs
ParticipantInteresting, this doesn’t seem to work for me. When I duplicate and move the armature with a set position puzzle I can see in console that it moves but the mesh stays put
2024-06-19 at 11:55 pm #75065kdv
ParticipantTry to parent the mesh to its armature before cloning (in Blender or via puzzles).
