Home › Forums › General Questions › Can’t get rid of light leaks from directional light.
- This topic has 11 replies, 4 voices, and was last updated 3 years, 7 months ago by
Mikhail Luzyanin.
2021-06-02 at 1:49 pm #41793
KurtGR
CustomerI’ve tried to tweak/rotate the directional light, changing bias/filter size/resolution e.t.c, and I can’t seem to get rid of that big light leak on the inside corner of the building. Is this a limitation of WebGL or a bug?
2021-06-02 at 2:56 pm #41798Mikhail Luzyanin
StaffNot sure can you share only this inner piece of mesh with sun and world setup in the scene?
2021-06-03 at 10:24 am #41832KurtGR
Customerhttps://we.tl/t-wxvrAfXR3h – Here’s a simplified version (the building is built in code as its a configurator app, but I put one together in the same fashion manually.
I also have another problem, not sure if its a known issue or if I should make another thread, but after updating to 3.7 Maya, sneak peak doesn’t work anymore (so I can’t even quickly test this scene to see if the leaks are still there, so please let me know! cheers).
2021-06-04 at 6:45 am #41857Mikhail Luzyanin
StaffMay be ther’s something in the texture that you not included? Because I can’t find anything simmilar.
2021-06-04 at 6:57 am #41861GLiFTeK
CustomerAlmost looks like an inverted ambient occlusion map.
Cool product.
Is that for designing modular small living spaces?
Shipping containers?Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2021-06-04 at 9:42 am #41864KurtGR
CustomerThere’s no AO map – I didn’t bother including textures because it was just to troubleshoot the lightleak – it seems it’s not there anyway because I built it by hand. I think maybe it’s a problem with the way the building is generated in code.
We build garden rooms for use as offices/studios/gyms e.t.c – http://www.greenretreats.co.uk, configurator goes live very soon.
2021-06-04 at 9:43 am #41865KurtGR
CustomerDo you know why my sneak preview button doesn’t work in Maya 3.7?
2021-06-05 at 12:24 am #41877GLiFTeK
CustomerThat’s great.
Would love to see it when it’s up!Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2021-08-11 at 3:37 pm #43578Muhammad Ebrahim
Customerhave you found where the problem is coming from??? I’m suffering the same issue… here:
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:04035fd58d/applications/Kitchino/Kitchino.html
the spotlights are not stopped by the surfaces, it’s passing through… these surfaces cast shadow in rendering options, and even double sidededit: they are also water tight… no open edges
2021-08-12 at 6:17 am #43582Mikhail Luzyanin
StaffThat’s how the environment reflections works in realtime they not respect any object that cover the environment and reflect throught them.
2021-08-13 at 6:44 pm #43643Muhammad Ebrahim
Customerany work around?
how do you solve this?
2021-08-16 at 8:31 am #43662Mikhail Luzyanin
StaffUnfortunally, we are not solving this, leaving it as is or remove environment light and lighten the scene using only point/directional light with shadows enabled.
