Home › Forums › WebGL & WebXR Troubleshooting › Can’t enter AR on iOS using button in parent doc
- This topic has 7 replies, 2 voices, and was last updated 2 years, 7 months ago by
Brameister.
2023-10-03 at 12:03 pm #67268
Brameister
ParticipantHi, everyone!
I’m following the AR example puzzles, but instead of creating the HTML button via puzzles, I wanted to use a button I had already created on the UI. However, when I check the “in parent doc” box in the puzzles, the button simply does not work in iOS devices, but it does work fine in Android.
I tried both with and without the “if feature available iOS” puzzle you see in the screenshot.
Why is the button not working in iOS?
2023-10-03 at 4:16 pm #67271kdv
ParticipantShare the link to your app or at least show the HTML code for that button. Not enough info.
2023-10-03 at 6:53 pm #67274Brameister
ParticipantSure thing.
Here’s the link to the app
2023-10-03 at 7:07 pm #67275kdv
ParticipantAnd which element on the page is supposed to have an id named “enter_AR_button”? As I see none of them has.
2023-10-03 at 7:11 pm #67276Brameister
ParticipantI changed the ID to “botao_ar”, and later changed it in the puzzles too. I thought I’d leave the original ID in the screenshot above to avoid any confusion. But the ID in the HTML element and in the puzzles is “botao_ar”.
2023-10-03 at 7:13 pm #67278kdv
ParticipantI changed the ID to “botao_ar”, as reflected in the puzzles
Really? Where?
And one more very important thing:
<div>won’t do for the AR button in iOS. Only<a>will do.Puzzles and JS coding. Fast and expensive.
2023-10-03 at 7:30 pm #67280Brameister
2023-10-03 at 7:32 pm #67281Brameister
ParticipantAnd one more very important thing:
I think that is probably the issue, right? I’ll try to figure out how to use in this case. Thanks for the help!
