Home › Forums › General Questions › Can’t Animate Light Scale/Size
- This topic has 4 replies, 2 voices, and was last updated 11 months, 3 weeks ago by
Brameister.
2024-04-09 at 4:53 pm #72215
Brameister
ParticipantIt seems Verge3D does recognize any Position or Rotation animation when it comes to lights, but not a Scale animation. I tried animating both Scale and the actual Size parameter in the Object Data Properties in Blender, but neither worked. Is that right? Is there no way to animate changes in a light source’s size?
2024-04-09 at 6:34 pm #72216kdv
ParticipantWhat do you expect to get from scaling a light source? It has some sense only for area or spot lights. Point lights and directional lights has no dimensions…
2024-04-10 at 10:23 pm #72254Brameister
ParticipantI’m using area lights representing LED strips built into furniture. For example, when the furniture’s width changes, I need the lenghth of the area light to change accordingly
2024-04-11 at 5:51 am #72260kdv
ParticipantArea lights also have no dimensions and it’s useless to scale them (0*20=0). But they have two specific properties: width and height. You can control those properties via JS.
https://www.soft8soft.com/docs/api/en/lights/RectAreaLight.htmlPuzzles and JS coding. Fast and expensive.
2024-04-11 at 2:56 pm #72281Brameister
ParticipantRight on!
I think I figured it out with your help. For anyone else that may encounter this problem, here’s the code I used in an Exec Script puzzle that worked for me:
// Define a function to update LED widths
function updateLEDWidths() {
// Access the slider in the parent document
var sliderValue = parent.document.getElementById(‘your_element_id’).value;// Map the slider value ([your range of slider values (e.g. 10 to 20)]) to the LED width ([range of Area Light X values (e.g 0.45 to 0.86)])
var ledWidth = mapRange(sliderValue, 10, 20, 0.45, 0.86);// Update the width of each Area light
var ledNames = [‘LED 1’, ‘LED 2’, ‘LED 3’, ‘LED 4’];
ledNames.forEach(function(ledName) {
// Assuming ‘app’ is your Verge3D app instance accessible in this context
var led = app.scene.getObjectByName(ledName);
if (led && led.isRectAreaLight) {
led.width = ledWidth;
}// Helper function to map a value from one range to another
function mapRange(value, inMin, inMax, outMin, outMax) {
return (value – inMin) * (outMax – outMin) / (inMax – inMin) + outMin;
}// Ensure this code runs after the Verge3D app is fully initialized
// You might need to place this inside a function that’s called after app initialization
updateLEDWidths();// Add an event listener to the slider in the parent document to update LED widths on change
parent.document.getElementById(your_element_id’).addEventListener(‘input’, updateLEDWidths); -
