Cannot Specify the imageURL for the SimplePreloader in 2.15.0-pre2
Home Forums Bug Reports and Feature Requests Cannot Specify the imageURL for the SimplePreloader in 2.15.0-pre2
  • #19193
    jem
    I cannot get the SimplePreloader class to use a user-specified image in place of the gear image in 2.15.0-pre2.
    In past builds of Verge3D, I was able to have the SimplePreloader class use my own image in place of the gear by passing its constructor a value for imageURL in its arguments. This was an easy way of putting a logo of my own choosing on a loading screen. This was done like this:
        var preloader = initOptions.useCustomPreloader
                ? createCustomPreloader(initOptions.preloaderProgressCb,
                initOptions.preloaderEndCb)
                : new v3d.SimplePreloader({ container: 'container' , imageURL:'my_logo_animated.gif', imageRotationSpeed: 90});
    The preloader in 2.15.0-pre2 seems to ignore the imageURL property. Is this a bug? If not, is there a simple way to replace the spinning gear?
    Thank you.
    Jeremy Wernick
    #19194
    SimplePreloader styling (images, colors, sizes etc) is now done using CSS classes. Please specify the background-image property on the v3d-simple-preloader-gear class to change gear image:
    .v3d-simple-preloader-gear {
        background-image: url("PATH_TO_YOUR_IMAGE");
    X | FB | LinkedIn
    #19195
    You can also use the src/style.css file as a reference if you need to change other CSS options for preloader, annotations, WebGL errors etc.
    X | FB | LinkedIn
    #19199
    Unfortunately, there was an issue in the style processing code preventing proper gear image styling. It should be fixed by now. Please re-download your pre2 build and update the v3d.js module in your app.
    X | FB | LinkedIn
    #19203
    jem
    Hi Alexander, I was able to get my logo to work using your CSS suggestion. Thank you for the very quick fix!
    Jeremy Wernick
    #19214
    Glad we could help!
