Cannot read property ‘dispose’ of null
Home Forums Bug Reports and Feature Requests Cannot read property ‘dispose’ of null
  • #29876
    web
    I’ve got an issue creating a material on runtime. I get the error “Cannot read property ‘dispose’ of null” in the console.
    However the application is running normal and the material is also created normally. But I would like to get rid of that error.
    Maybe it has something todo with the 3.3.0 pre1 version I’m testing.
    This is the code:
    var video = loadVideo('./assets/Testvideo.mp4');
    var singleObj = getObjectByName('Testobject');
    var texture = new v3d.VideoTexture(video);
    singleObj.material = new v3d.MeshStandardMaterial({ emissive : 0xFFFFFF, emissiveMap : texture, emissiveIntensity: 0.7});
    #29992
    That’s strange. dispose happens when you’re unloading something. Are you sure these lines of code generate the error?
    X | FB | LinkedIn
    #30001
    web
    As soon as I got the last line for creating the material I get this error. At the moment the workaround I’m using is creating a “MeshLambertMaterial” instead of “MeshStandardMaterial”. With the lambert one there is no error, dont know why? :unsure:
    #30036
    I made a simple test case based on your code, still no errors :unsure: Can you share a link to your project sources?
    X | FB | LinkedIn
    #30125
    web
    I think I found the issue. I’ve upped the world cubemap res on runtime. As soon as I got the updateEnvironment in the code, I get the error with the MeshStandardMaterial.
    This is the code in the runCode()
    app.worldCubemapRes = 2048;
    app.updateEnvironment(app.worldMaterial);
    This is the error log in chrome:
    v3d.js:1 Uncaught TypeError: Cannot read property 'dispose' of null
    at v3d.js:1
    at v3d.js:1
    at Ci.traverse (v3d.js:1)
    at zn.traverse (v3d.js:1)
    at sy._traverseSceneForEnvUpdates (v3d.js:1)
    at sy.disposeEnvironment (v3d.js:1)
    at sy.updateEnvironment (v3d.js:1)
    at runCode (test.js?ver=0.1:227)
    at test.js?ver=0.1:96
    at v3d.js:1
    #30136
    Thanks for investigating the issue! It will be fixed in the next verge3d update.
    #30148
    web
    Great :good:
