Home › Forums › Puzzles › Can you create a digital box in verge 3D puzzle to change the size of an object?
- This topic has 10 replies, 3 voices, and was last updated 4 years, 11 months ago by
alifsubandi.
2019-02-20 at 2:31 am #11565
Citrus sinensis
ParticipantThank you for your reply yesterday.
My problem is that I can already change the size of an object by pushing and pulling in a jigsaw puzzle, which is very close to what I want. What I want most is whether we can set up a numerical box in verge 3D puzzle to change the length, width and coordinate XYZ of the object by numerical value. This is very helpful to my work.
Thank
2019-02-20 at 7:29 am #11569Mikhail Luzyanin
StaffWhat I want most is whether we can set up a numerical box in verge 3D puzzle to change the length, width and coordinate XYZ of the object by numerical value.
You can setup numerical the scale of the object using Puzzle Set Scale.
2019-02-20 at 8:35 am #11574Citrus sinensis
ParticipantThank you very much for your reply.
I’ve found Puzzle Set Scale and guided how to change the values.
But my problem is still unsolved.
1. The position of the door panel can be moved by entering values into the input boxes of x, y and Z.
2. The size of the door panel can be changed by inputting values to wide, deep and thick input boxes (ZS, ZX, YS, YX module size is fixed and unchangeable; for example, the default width is 400 mm, when the input size is 600 mm, the width of S, Z, X will increase by 200, YS, Y, YX will move to the right by 200 mm).
It is very difficult to implement the above operation.
You must be logged in to view attached files.2019-02-20 at 8:44 am #11578Mikhail Luzyanin
StaffIt’s better to attach a whole project with puzzles, not only a blend file, because a problem mostly in logic I think.
2019-02-20 at 8:50 am #11581Citrus sinensis
ParticipantI’ll try again to see if I can solve this problem
2019-02-20 at 9:15 am #11582Citrus sinensis
ParticipantI want to change my mind, and the difficulties will be improved.
Now the problem is that in SketchUp, the origin of the object’s coordinates is in the lower left corner. In blender, the coordinate origin of the object is at the center of the object.
The question I want to ask is how to change the coordinate center of an object in blender so that it is in the lower left corner of the object.
If the central point of the object is changed, will the central point of the object be changed in the jigsaw puzzle?
Thank you very much.
2019-02-20 at 12:14 pm #11585Mikhail Luzyanin
StaffThe question I want to ask is how to change the coordinate center of an object in blender so that it is in the lower left corner of the object.
Select any object then you need to enter edit mode, then select the lower left vetex of the object then ctlr-s ans select Cursor to Selected then returnd to object mode and ctrl+shift+alt+C and select Origin to 3D-Cursor.
Yes, the origin will be inherit from the file so it will be the same as in Blender.
2019-02-21 at 1:00 am #11600Citrus sinensis
ParticipantYour answer has helped me a lot. Thank you very much.
2020-03-26 at 7:25 am #24983alifsubandi
ParticipantDear all Verge3d expert..:)
Im wondering is verge 3D can do interactive profile in the puzzle.
example: i have 3 different table design, and i wanna make an interactive verge 3d for them. so when i click a button, table 1 will displayed. and when i click other button, table 2 will displayed, etc.
which puzzle i must use?
2020-03-26 at 8:20 am #24985Mikhail Luzyanin
Staffexample: i have 3 different table design, and i wanna make an interactive verge 3d for them. so when i click a button, table 1 will displayed. and when i click other button, table 2 will displayed, etc.
Yes, most of the demos made this way.
You need hide/show puzzle.
2020-04-13 at 3:54 am #25680alifsubandi
ParticipantThank you so much, it help me a lot
