Home › Forums › General Questions › Can we run published V3d file offline ?
- This topic has 14 replies, 5 voices, and was last updated 2 years, 7 months ago by
visualizer.
2021-12-21 at 5:45 pm #48192
visualizer
CustomerHi
Its been a while since Yuri & team answered for similar question. However V3d is much improved & reaching to a pro-tool category.I wonder is it possible to load the published verge 3d files offline on the machine ?
Is there any kind of settings or localhost setup which enables it to run offline instead of running from server?
Thx
2021-12-22 at 7:53 am #48200Yuri Kovelenov
StaffHi,
Using Electron converter is the most straightforward way to create offline apps
https://www.soft8soft.com/docs/manual/en/introduction/Creating-Desktop-Apps.html
2021-12-22 at 7:07 pm #48214visualizer
CustomerAAh
Yuri!
Great thank you!2022-05-28 at 10:17 am #52479visualizer
CustomerHi
I tried creating offline with above clue but found after clicking on create ..template button I found the progress round is running forever. Even after 30-35 min it was still running. I tried same on 2-3 different machines.AM I missing any external files or any settings?
You must be logged in to view attached files.2022-06-04 at 1:30 pm #52664visualizer
CustomerHi
YuriAny comment son above query plz?
2022-06-04 at 3:29 pm #52665xeon
CustomerYou can always create your own local server and run it that way if that’s an option.
Tutorials - https://www.xeons3dlab.com2022-06-06 at 2:11 pm #52688visualizer
CustomerHey Xeon,
thank you for the clue. Yes I agree & I remember these things from my past. the developers do it many times.I m just wondering how to use option in verge 3d ?
2022-06-16 at 8:58 am #53191Ivan Lyubovnikov
StaffHi visualizer,
The process of creating a desktop app can hang when the App Manager tries to download Electron binaries (only needed first time) if you have problems with your internet connection. To check if that’s the case you can view the server logs. If you run the App Manager via the desktop icon as shown here: https://www.soft8soft.com/docs/manual/en/introduction/App-Manager.html#Using_Desktop_Application then you can see the logs in the opened console window:
You must be logged in to view attached files.Co-founder and lead developer at Soft8Soft.
2022-06-20 at 4:41 am #53333visualizer
CustomerHi
Ivan,
You mean first time it may take longer tiem but later it should work normal?2022-06-20 at 6:21 am #53336Ivan Lyubovnikov
StaffYou mean first time it may take longer tiem but later it should work normal?
Yes, in general. But I suspect that in your case the whole process just stalls because the app manager can’t download the Electron binaries for some reason.
2022-06-29 at 2:16 pm #53750visualizer
CustomerOh
is there any solution?2022-06-29 at 2:51 pm #53752Pascal
CustomerPossibly the process already finished but just the progress-dialog in the browser doesn’t disappear as expected. Did you check if the output got created?
2022-07-03 at 9:32 am #53827visualizer
CustomerHi
Pascal,May be but where the generated files are stored?
I searched all possible locations but couldn’t locate anything.2022-07-05 at 12:25 pm #53868Yuri Kovelenov
Staff2022-08-21 at 6:54 am #55055visualizer
CustomerHey
YuriI just checked the custom image sample from the default set of verge 3d and yes the offline set got successfully prepared in few moments.
Regards
