Home › Forums › General Questions › can we get camera co-ordinate in verge scene
- This topic has 5 replies, 3 voices, and was last updated 3 years, 11 months ago by
nmcandre.
2021-03-19 at 5:25 pm #39596
visualizer
CustomerHello
Hi team,Is it possible to get the camera coordinates out from published scene of verge 3d?
Example – If I have a verge 3d scene published with some room environment, is it possible to trace the live camera position of the user handling to some output file?Yuri & Team?
Regards
2021-03-21 at 3:34 am #39618GLiFTeK
CustomerYou can designate your camera to a variable puzzle, then use an exec JavaScript puzzle.
Make a puzzle variable named “myCameraPuzzleVar”…
Give it the value of the selector puzzle of the camera object.
And create a recieving puzzle variable named “camPosAll”…
plugged a logic puzzle “null” into that just to register it.Then make:
Exec Code within something like:var camera = VARS['myCameraPuzzleVar']; var camObj = app.scene.getObjectByName(camera); var camPosX = camObj.position.x; var camPosY = camObj.position.y; var camPosZ = camObj.position.z; var camPosAll = [camPosX, camPosY, camPosZ]; VARS['camPosAll'] = camPosAll;
Doing this from mobile so some things might need adjusting.
plz share Discord link & on your signature!2021-03-21 at 2:31 pm #39625visualizer
CustomerHey
GlifTekThat sounds interesting !
I think in broader sense I understand what you say. I need to check with my developer to make it working.
Hope it will get throughRegards
2021-05-06 at 12:01 pm #40806nmcandre
ParticipantHi,
I am testing the Verge 3D for Blender and I need to get the camera positional coordinates and rotation, write it on a text file (for example a csv).
Is it possible to do it? If so, how can I can do it?
Thanks.
Regards,
Nuno2021-05-07 at 6:15 am #40835visualizer
CustomerHi
nmcandreyes I am also looking for the similar outputting the camera coordinates but my need is little dynamic.
one thing as you said it can be in text or csv file.
Second I m expecting is if camera keeps changing its position in scene how that dynamic changing can be updated constantly ?
Is there any way? Developers can you throw some light ?Example –
I have “A” verge 3d scene with user moving here & there while in the “B” verge 3d scene is fetching the camera co-ordinates from “A” continuously and showing some representation of that camera movement from scene “A” in the current scene “B” & may be vice versa.Regards
2021-05-07 at 12:53 pm #40842nmcandre
ParticipantHi visualizer,
I think that I need also the dynamic update on camera position. I’ll give you my example:
On the web browser the user can rotate, pan and zooming the camera freely. At any position he could need a high resolution rendered image.
If I have the actual position of the camera outside the web browser I can make a python script to run the render at exactly those coordinates seen.
If I find a way of doing it I’ll share here.
Regards,
Nuno -
