can verge3d achieve this kind of effect? How?
Home Forums General Questions can verge3d achieve this kind of effect? How?
  • #37159
    chris2616
    I find a very attractive info showcase:
    Supercharger vs. Turbo
    https://animagraffs.com/
    Can I use verge3d achieve this kind of effect? How to simulate data flow effect in Blender or puzzles? This confuse me a lot. Is there any tutorials or docs talk about this part? so many questions, THANKS :)
    #37164
    this all is just Blender animation. Arrows are textures with animated UV. Transparent part must be implemented without depth writes. https://www.soft8soft.com/docs/manual/en/blender/Transparency.html#alpha_add
    #37253
    chris2616
    thank you :good:
    Does verge3d suopport embeding GIF to achieve the similar effect?
    #37260
    you can use texture atlase – see our Industrial Robot demo where it is used for welding sparkles
    #37330
    Avier3D
    deleted: found the info I was looking for.
    #37354
    visualizer
    Avier3D
    The effect you are talking above is achieved by the Blend4web addon for blender. It was very nicely done.
    I really love to see similar thing happening in V3D.
    I m not sure whether current shader in V3D can achieve the volumetric effect of material with fallout behavior. The way the manifolds are shown filled up with blue gas.
    Especially the enable / disable the within document 3D effect is also nice !
    Developer kindly throw some light.
    Regards
