Can V3d receive window.postMessage events?
Home Forums General Questions Can V3d receive window.postMessage events?
Viewing 12 posts - 1 through 12 (of 12 total)
  • #31520
    grimmy
    I am told this is a good way to communicate between iframes and the current page but I cant find anything in puzzle to listen to such events.
    Is there a way?
    Thanks
    #31534
    there is no such puzzles yet, sorry, but you can implement this with JavaScript and link with the Puzzles as show here:
    https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
    #31551
    grimmy
    Thanks for this but I tried a few variations and cant get it to work. Maybe my situation is slightly different to those described in the manual(?):
    I have a parent app which has the verge3d app embedded as an iframe. I want the parent app to perform some function on the v3d<iframe>. Im using postMessage from the parent app to send something to the iframe but I’m just not sure how the v3d iframe picks up the message.
    #31553
    grimmy
    I have the solution for anyone wishing to try the same thing:
    In my parent app I send the message like so:
    var myIframe = document.getElementById('v3d_iframe');//Note:I have set the ID of my iframe to v3d_iframe
    myIframe.contentWindow.postMessage('myMsg', '*');
    In my awesom_application.js script I make a message listener like so:
    window.onmessage = function(event){
        if (event.data == 'myMsg') {
            console.log('myMsg Message received!');
    However I still don’t know how I would go about sending more data (variables) to the v3d window…if anyone has any ideas let me know..
    #31557
    grimmy
    In order to send a bunch of data to the v3d iframe you can do this:
    Parent:
            event_id: 'myMessage',
            data: {
                v1: 'value1',
                v2: 'value2'
    v3d iFrame (in my_awesome_app.js for example):
    window.onmessage =  function(event) {
        if(event.data.event_id === 'myMessage'){
            console.log(event.data.data);
    #31573
    Awesome! Thank you for sharing your solution! :good:
    #63266
    solid
    it turns out that the data can be transferred back?
    #63267
    What do you mean? Back to where?
    #63268
    solid
    passing window.postmessage to the parent page
    window.parent.postMessage('scene_loaded', "*");
    • This reply was modified 1 year, 11 months ago by solid.
    #63270
    You may try. I suppose it’s quite possible.
    #74577
    rainman
    Could the receiving code be placed in a “ecec script” puzzle. Also would this method fix my cross origin policy issues.
    #74578
    No. JS in iFrame won’t work.
