can the gltf model be added mouse event
Home Forums Puzzles can the gltf model be added mouse event
  • #23147
    wlhm1984
    how to add the gltf model mouse event while the gltf model is used “append scene” load to the scene.
    #23148
    You need to insert a when clicked puzzle in the when loaded do slot of the append scene puzzle.
    You should also use a Text puzzle rather than a selector puzzle in order to specify the name of your object.
    #23157
    wlhm1984
    thanks for your reply,but i can not understand how to do ,i give you a photo.
    #23183
    you need a when clicked puzzle, and use your object name in the text field, not the path
    #23188
    wlhm1984
    thanks for your reply,it is ok,i want to append the same gltf model several times,how to give them different name.
    #23197
    you can load a gltf file once, and then use the clone puzzle to make copies
    https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#clone
